You are right, it is the same issue.For the moment, the best workaround is to unset SnapToLevels bu it should be fixed for final.
if (e.OldExtent.Equals(e.NewExtent)) { return; }
And yes, I am able to replicate the problem in the sample by adding SnapToLevels and Min/Max resolution.
<UserControl x:Class="ESRI_Test.MainPage" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:esri="http://schemas.esri.com/arcgis/client/2009"> <Grid x:Name="LayoutRoot" Background="White"> <Grid.Resources> <esri:SimpleLineSymbol x:Key="DrawLineSymbol" Color="Green" Width="4" /> <esri:SimpleFillSymbol x:Key="DrawFillSymbol" Fill="#3300FF00" BorderBrush="Green" BorderThickness="2" /> <esri:SimpleMarkerSymbol x:Key="DefaultMarkerSymbol" Color="Red" Size="12" Style="Circle" /> <esri:SimpleLineSymbol x:Key="DefaultLineSymbol" Color="Red" Width="4" /> <esri:SimpleFillSymbol x:Key="DefaultFillSymbol" Fill="#33FF0000" BorderBrush="Red" BorderThickness="2" /> </Grid.Resources> <esri:Map x:Name="MyMap" Extent="-15000000,2000000,-7000000,8000000" SnapToLevels="True" MinimumResolution="0.0746126492252985" MaximumResolution="1222.99245256249"> <esri:ArcGISTiledMapServiceLayer ID="StreetMapLayer" Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/> <esri:GraphicsLayer ID="MyGraphicsLayer" /> </esri:Map> <Canvas Width="370" Height="110" HorizontalAlignment="Right" VerticalAlignment="Top" Margin="0,15,15,0" > <Rectangle Stroke="Gray" RadiusX="10" RadiusY="10" Fill="#77919191" Canvas.Left="0" Canvas.Top="0" Width="370" Height="110" > <Rectangle.Effect> <DropShadowEffect/> </Rectangle.Effect> </Rectangle> <Rectangle Fill="#FFFFFFFF" Stroke="DarkGray" RadiusX="5" RadiusY="5" Canvas.Left="10" Canvas.Top="10" Width="350" Height="90" /> <TextBlock x:Name="ToolTile" Foreground="Black" Width="340" TextAlignment="Center" FontSize="9" FontWeight="Bold" Canvas.Left="20" Canvas.Top="10" Text="Use these tools to add graphics to the map." /> <StackPanel Orientation="Vertical" Canvas.Top="5" Canvas.Left="20"> <esri:Toolbar x:Name="MyToolbar" MaxItemHeight="80" MaxItemWidth="80" Grid.Row="0" VerticalAlignment="Top" HorizontalAlignment="Center" ToolbarItemClicked="MyToolbar_ToolbarItemClicked" ToolbarIndexChanged="MyToolbar_ToolbarIndexChanged" Width="330" Height="80"> <esri:Toolbar.Items> <esri:ToolbarItemCollection> <esri:ToolbarItem Text="Add a point"> <esri:ToolbarItem.Content> <Image Source="Assets/images/i_draw_point.png" Stretch="UniformToFill" Margin="5" /> </esri:ToolbarItem.Content> </esri:ToolbarItem> <esri:ToolbarItem Text="Add a Polyline"> <esri:ToolbarItem.Content> <Image Source="Assets/images/i_draw_line.png" Stretch="UniformToFill" Margin="5" /> </esri:ToolbarItem.Content> </esri:ToolbarItem> <esri:ToolbarItem Text="Add a Polygon"> <esri:ToolbarItem.Content> <Image Source="Assets/images/i_draw_poly.png" Stretch="UniformToFill" Margin="5" /> </esri:ToolbarItem.Content> </esri:ToolbarItem> </esri:ToolbarItemCollection> </esri:Toolbar.Items> </esri:Toolbar> <TextBlock x:Name="StatusTextBlock" Text="" FontWeight="Bold" HorizontalAlignment="Center"/> </StackPanel> </Canvas> </Grid> </UserControl>
using System.Windows.Controls; using ESRI.ArcGIS.Client; using ESRI.ArcGIS.Client.Symbols; namespace ESRI_Test { public partial class MainPage : UserControl { private Draw MyDrawObject; private Symbol _activeSymbol = null; public MainPage() { InitializeComponent(); MyDrawObject = new Draw(MyMap) { LineSymbol = LayoutRoot.Resources["DrawLineSymbol"] as LineSymbol, FillSymbol = LayoutRoot.Resources["DrawFillSymbol"] as FillSymbol }; MyDrawObject.DrawComplete += MyDrawObject_DrawComplete; } private void MyToolbar_ToolbarItemClicked(object sender, ESRI.ArcGIS.Client.Toolkit.SelectedToolbarItemArgs e) { switch (e.Index) { case 0: // Point MyDrawObject.DrawMode = DrawMode.Point; _activeSymbol = LayoutRoot.Resources["DefaultMarkerSymbol"] as Symbol; break; case 1: // Polyline MyDrawObject.DrawMode = DrawMode.Polyline; _activeSymbol = LayoutRoot.Resources["DefaultLineSymbol"] as Symbol; break; case 2: // Polygon MyDrawObject.DrawMode = DrawMode.Polygon; _activeSymbol = LayoutRoot.Resources["DefaultFillSymbol"] as Symbol; break; case 3: // Rectangle MyDrawObject.DrawMode = DrawMode.Rectangle; _activeSymbol = LayoutRoot.Resources["DefaultFillSymbol"] as Symbol; break; case 4: // Freehand MyDrawObject.DrawMode = DrawMode.Freehand; _activeSymbol = LayoutRoot.Resources["DefaultLineSymbol"] as Symbol; break; default: // Clear Graphics MyDrawObject.DrawMode = DrawMode.None; GraphicsLayer graphicsLayer = MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer; graphicsLayer.ClearGraphics(); break; } MyDrawObject.IsEnabled = (MyDrawObject.DrawMode != DrawMode.None); } private void MyToolbar_ToolbarIndexChanged(object sender, ESRI.ArcGIS.Client.Toolkit.SelectedToolbarItemArgs e) { StatusTextBlock.Text = e.Item.Text; } private void MyDrawObject_DrawComplete(object sender, ESRI.ArcGIS.Client.DrawEventArgs args) { GraphicsLayer graphicsLayer = MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer; ESRI.ArcGIS.Client.Graphic graphic = new ESRI.ArcGIS.Client.Graphic() { Geometry = args.Geometry, Symbol = _activeSymbol, }; graphicsLayer.Graphics.Add(graphic); } } }
