I have a script that I am trying to move over to Pro but I am having problems with updating text the layout .
The text "Template" in the layout doesn't get updated by arcpy.GetParameterAsText. I don't know why it doesn't update, I don't get any errors.
<SPAN class="keyword token">import</SPAN> arcpy<SPAN class="punctuation token">,</SPAN> string<SPAN class="punctuation token">,</SPAN> os
aprx <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mp<SPAN class="punctuation token">.</SPAN>ArcGISProject<SPAN class="punctuation token">(</SPAN>r<SPAN class="string token">"C:\Temp\ArcGISProTest.aprx"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#acc_val = arcpy.GetParameterAsText(0)</SPAN>
project <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mp<SPAN class="punctuation token">.</SPAN>ArcGISProject<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"CURRENT"</SPAN><SPAN class="punctuation token">)</SPAN>
layer1 <SPAN class="operator token">=</SPAN> project<SPAN class="punctuation token">.</SPAN>listMaps<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
lyr <SPAN class="operator token">=</SPAN> layer1<SPAN class="punctuation token">.</SPAN>listLayers<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"TAXLOTS"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
lyt <SPAN class="operator token">=</SPAN> project<SPAN class="punctuation token">.</SPAN>listLayouts<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Layout1"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
mf <SPAN class="operator token">=</SPAN> lyt<SPAN class="punctuation token">.</SPAN>listElements<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'MAPFRAME_ELEMENT'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'*'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>dirname<SPAN class="punctuation token">(</SPAN>project<SPAN class="punctuation token">.</SPAN>filePath<SPAN class="punctuation token">)</SPAN>
wp <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>dirname<SPAN class="punctuation token">(</SPAN>project<SPAN class="punctuation token">.</SPAN>filePath<SPAN class="punctuation token">)</SPAN>
values <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN>
fieldName <SPAN class="operator token">=</SPAN> <SPAN class="string token">"ParID"</SPAN>
values <SPAN class="operator token">=</SPAN> values<SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="string token">";"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># split values into list</SPAN>
values <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"'{0}'"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>v<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> v <SPAN class="keyword token">in</SPAN> values<SPAN class="punctuation token">]</SPAN> <SPAN class="comment token"># add single quotes</SPAN>
whereClause <SPAN class="operator token">=</SPAN> <SPAN class="string token">"{0} IN ({1})"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>fieldName<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">","</SPAN><SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>values<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>lyr<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> whereClause<SPAN class="punctuation token">)</SPAN>
Name <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> lyt <SPAN class="keyword token">in</SPAN> aprx<SPAN class="punctuation token">.</SPAN>listLayouts<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> elm <SPAN class="keyword token">in</SPAN> lyt<SPAN class="punctuation token">.</SPAN>listElements<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"TEXT_ELEMENT"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> elm<SPAN class="punctuation token">.</SPAN>text <SPAN class="operator token">==</SPAN> <SPAN class="string token">"Template"</SPAN><SPAN class="punctuation token">:</SPAN>
elm<SPAN class="punctuation token">.</SPAN>text <SPAN class="operator token">=</SPAN> Name
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>lyr<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"SHAPE@"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"ParID"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
featureextent <SPAN class="operator token">=</SPAN> mf<SPAN class="punctuation token">.</SPAN>getLayerExtent<SPAN class="punctuation token">(</SPAN>lyr<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Set mapframe camera to featureextent</SPAN>
mf<SPAN class="punctuation token">.</SPAN>camera<SPAN class="punctuation token">.</SPAN>setExtent<SPAN class="punctuation token">(</SPAN>featureextent<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Reduce mapframe slightly to avoid feature clipping.</SPAN>
mf<SPAN class="punctuation token">.</SPAN>camera<SPAN class="punctuation token">.</SPAN>scale <SPAN class="operator token">*=</SPAN> <SPAN class="number token">1.2</SPAN>
<SPAN class="comment token">#arcpy.RefreshActiveView()</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
