I have set up a test account to check processing instructions for a group of students. Now on trying t open the Map I am getting the message: Error - you do not have permission to access this resource
Hello, Student_Dummy S !
Another way you can check what your map sharing is set to is by:
Hi dummyaccount ,
Is the account that you are using to access the map, the same account used to create the map? If not, did you share the map? If so, is it shared with a group (is the user that tries to have access a member of that group?), with your organization or the public?
Thanks for the information it helps
Thank you
