Greetings,
In WAB 2.3, using the add data widget, is there a way to set it to sort by title as the default? Any assistance would be greatly appreciated!
Jason
Jason,
You need to make changes in two files:
[install dir]\server\apps\[app#]\widgets\AddData\search\SortOptions.js line 31:
<SPAN class="comment token">///////////////////////////////////////////////////////////////////////////</SPAN> <SPAN class="comment token">// Copyright © 2016 Esri. All Rights Reserved.</SPAN> <SPAN class="comment token">//</SPAN> <SPAN class="comment token">// Licensed under the Apache License Version 2.0 (the "License");</SPAN> <SPAN class="comment token">// you may not use this file except in compliance with the License.</SPAN> <SPAN class="comment token">// You may obtain a copy of the License at</SPAN> <SPAN class="comment token">//</SPAN> <SPAN class="comment token"><SPAN>// </SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fwww.apache.org%2Flicenses%2FLICENSE-2.0" target="_blank">http://www.apache.org/licenses/LICENSE-2.0</A></SPAN> <SPAN class="comment token">//</SPAN> <SPAN class="comment token">// Unless required by applicable law or agreed to in writing, software</SPAN> <SPAN class="comment token">// distributed under the License is distributed on an "AS IS" BASIS,</SPAN> <SPAN class="comment token">// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.</SPAN> <SPAN class="comment token">// See the License for the specific language governing permissions and</SPAN> <SPAN class="comment token">// limitations under the License.</SPAN> <SPAN class="comment token">///////////////////////////////////////////////////////////////////////////</SPAN> <SPAN class="token function">define</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"dojo/_base/declare"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/on"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/dom-class"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"./SearchComponent"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/text!./templates/SortOptions.html"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/i18n!../nls/strings"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dijit/form/Select"</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>declare<SPAN class="punctuation token">,</SPAN> on<SPAN class="punctuation token">,</SPAN> domClass<SPAN class="punctuation token">,</SPAN> SearchComponent<SPAN class="punctuation token">,</SPAN> template<SPAN class="punctuation token">,</SPAN> i18n<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">return</SPAN> <SPAN class="token function">declare</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>SearchComponent<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> i18n<SPAN class="punctuation token">:</SPAN> i18n<SPAN class="punctuation token">,</SPAN> templateString<SPAN class="punctuation token">:</SPAN> template<SPAN class="punctuation token">,</SPAN> sortField<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"title"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
[install dir]\server\apps\[app#]\widgets\AddData\search\templates\SortOptions.html line 5 and 6:
(remove the selected property from line 5 and add it to line 6)
<SPAN class="operator token"><</SPAN>div <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"search-sort-options"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>label <SPAN class="keyword token">for</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"${id}_select"</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"sort-prompt"</SPAN><SPAN class="operator token">></SPAN>$<SPAN class="punctuation token">{</SPAN>i18n<SPAN class="punctuation token">.</SPAN>search<SPAN class="punctuation token">.</SPAN>sortOptions<SPAN class="punctuation token">.</SPAN>prompt<SPAN class="punctuation token">}</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>label<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>select id<SPAN class="operator token">=</SPAN><SPAN class="string token">"${id}_select"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">"dijit/form/Select"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>attach<SPAN class="operator token">-</SPAN>point<SPAN class="operator token">=</SPAN><SPAN class="string token">"sortSelect"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>option value<SPAN class="operator token">=</SPAN><SPAN class="string token">""</SPAN><SPAN class="operator token">></SPAN>$<SPAN class="punctuation token">{</SPAN>i18n<SPAN class="punctuation token">.</SPAN>search<SPAN class="punctuation token">.</SPAN>sortOptions<SPAN class="punctuation token">.</SPAN>relevance<SPAN class="punctuation token">}</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>option<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>option value<SPAN class="operator token">=</SPAN><SPAN class="string token">"title"</SPAN> selected<SPAN class="operator token">=</SPAN><SPAN class="string token">"selected"</SPAN><SPAN class="operator token">></SPAN>$<SPAN class="punctuation token">{</SPAN>i18n<SPAN class="punctuation token">.</SPAN>search<SPAN class="punctuation token">.</SPAN>sortOptions<SPAN class="punctuation token">.</SPAN>title<SPAN class="punctuation token">}</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>option<SPAN class="operator token">></SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Robert, THANK YOU for the 423rd time!!
