Did we lose the option for Bing basemaps?
I just reproduced what Dan outlined.
When I attempted to add a base map to ArcMap, the basemap opened in AGX as a new ArcGIS Layer and not in ArcMap.So, initial problem is kind of solved, but I don't think what just happened was by design.
Did we lose the option for Bing basemaps? I do like having the option to finally put text on the map - kudos for that.
Noticed that the Beta version is for 32-bit. Are there any plans to release a 64-bit version? We have done a lot of customization using the Add-in functionality within version 1750, will it still worj in 2012?Regards,Stefanssteenekamp@ppf.org.za
I seem to be in some strange loop for Add Ins, though. When I go to Resources > Add Ins, it asks if I want to restart to load one. Not sure what it's loading, but restart doesn't end the popup. I've got:Add Ins OnlineFile WithCoordinatesRaster GeoreferencingCreate or Add GeoTagged ImagesI'm also unable to remove any of them.I also had a third party Add In developed for search and rescue. I can't install that, though it worked on build 1750.Workaround is to keep 1750 on my machine. Can I then use 2012 beta off a USB?Thoughts and comments welcomeThanks!George
Hey,... Is it possible to add the new Web Feature Services hosted by ArcGIS Online or is it planned to add such a functionality? At the moment there only seems to be support for common GIS-server technologies. I think this would be a perfect addition to reach a maximum integration between both systems.best regardsRichard
Installed the beta last Friday.Background: I have used the previous version only a little, so there is a decent chance I am using it suboptimally and the performance issues I see are a result of user error.Use case: We have data in shapefiles representing streets in the USA and Canada. Supporting these feature classes and shapefiles are extra tables about maneuvers, etc. The data is stored centrally and is read only. I am evaluating ArcExplorer Desktop as a potential replacement for the couple copies of ArcView 3.3 the field collection guys use to study some tricky intersections. They load up the appropriate shapefile (usually half a million to a million streets) in AV 3.3 very quickly and the guys zoom to their intersection and use a combination of Identify, symbology, and occasionally relates to figure things out. We'd like to move off AV 3.3 before it stops working with some version of Windows. We'd also like to eventually move the data to geodatabase.Here's what I've tried: keeping the data in central shapefiles, local shapefiles, local filegeodatabase, local layer package.Here's what I've seen: ArcExplorer draws the shapes very, very slowing, spending a large amount of time telling me it is "streaming." I can start AV 3.3 and look at the data in the same time I am waiting for the data to render. The field guys will never accept this performance hit. In just a little looking, I was also not able to figure out how to handle the user need to look at other tables by relate. I didn't spend much time on it, though, because the slow drawing was a total deal breaker.I assume I am doing something incorrectly, but if the performance difference is unavoidable, I think our guys will want to stick with AV 3.3 - it is familiar and fast.What am I doing incorrectly?
You aren't necessarily doing anything incorrectly, but you may be able to get a better user experience by trying the following: [various good tips]Mark
Esri is phasing out the complimentary use of Bing Maps in its ArcGIS products. The final version of ArcGIS Explorer 2012 as well as other Esri products will be "Bing Ready", which will allow you to input a Bing Maps key that you obtain directly from Microsoft. After you input the key you will be able to use Bing maps as you did previously.Mark
Can you expand on this a little more? Will this be like the 9.2/9.3 days where you had to install Bing maps as an extenstion (virtual earth if i remember), which required registering with Microsoft and ESRI? Where are we to obtain a bing maps key in the future and where are we to input this key to gain access to Bing Maps. My agency already has a Bing Maps key but other people might want to know some details on this.
Just installed the beta and noticed the same atrocious symbology. Will there be ANY improvements to symbols in the 2012 release? As described to me once, the symbols in Explorer are way to "cartoony" and need to be more professional looking. There should be more of an option other than "use layer packages or use .lyr files". layer packages seem to have less functionality than directly adding shapefiles. Users can't change colors or mess with popups from a layer package. So if somebody wants different colors for something they have to go back to the source to get a new layer file.If the symbols won't be changed at least make it easier to install and use symbol or style packages from ArcGIS Desktop within Explorer. Or even allow users to download symbol packages or esri fonts. Something. But either way something has to be done with the symbology.
There are no plans to add or change the symbology in ArcGIS Explorer 2012. In regards to points you can add images to use as symbols. http://webhelp.esri.com/arcgisexplorer/2012//en/dialog_manage_my_symbols.htm#
