Anybody having trouble with the ArcGIS Connection failing in version 2500 with Windows 7? It doesn't seem to fail with any other 10.1 ArcGIS software. Here's the Windows Problem signature: Problem Event Name: APPCRASH Application Name: ArcGISConnectionBin.exe Application Version: 10.1.2.3252 Application Timestamp: 511165ea Fault Module Name: ntdll.dll Fault Module Version: 6.1.7601.17725 Fault Module Timestamp: 4ec49b8f Exception Code: c000071f Exception Offset: 0009a3b9 OS Version: 6.1.7601.2.1.0.256.48 Locale ID: 1033 Additional Information 1: a7aa Additional Information 2: a7aa91f17ea749d42a4de3b390fa5b3d Additional Information 3: a7aa Additional Information 4: a7aa91f17ea749d42a4de3b390fa5b3d
Have you tried this?http://forums.arcgis.com/threads/61829-ERROR-ArcGIS-is-currently-not-connected-to-online-resources?p=229388&viewfull=1#post229388
The following suggestion should resolve the issue: 1. Open Internet Explorer-> Tools->Internet Options->Connections-> LAN Settings and turn off "Automatically detect settings." Other Suggestions1. Navigate to Control Panel->Add/Remove Programs->Select ArcGIS Explorer for Desktop ->Uninstall/change->Repair.2. Try to ensure that you have the most current display driver installed on your client machine. Open Control Panel > Device Manager. Expand Display Adapters. Right click the adapter below this > Properties. Go to the Driver tab > Update Driver > Search Automatically. If you can upgrade, then install the newer driver.3. http://cyri.systemrequirementslab.com/cyri_if/1186/10895 Use ArcGIS Explorer behind a firewall: http://webhelp.esri.com/arcgisexplorer/2500/en/firewall.htmRegards,Robert LeClairEsri-Denver
The solution (#1) worked like a champ for my home computer, I'll try it on my work box tomorrow.
You're welcome Steven - all the best!
finally i found my fixeverything is working back to normal
How To Fix “Internet Explorer Has Stopped Working” Appcrash?
