###########Point to Raster
# Import arcpy module
import arcpy, os
from arcpy import env
from arcpy.sa import *
# Set environment settings
arcpy.env.workspace = "C:/py2/extract"
OutputFolder2 = "C:/py2/result"
# Loop through a list of files in the workspace
RasterFiles2 = arcpy.ListFeatureClasses()
print "POINT TO RASTER"
print RasterFiles2
print " "
# Set local variables
for filename2 in RasterFiles2:
print "Processing: {0}".format(filename2)
outRaster2 = os.path.join(OutputFolder2, filename2)
value = "RasterValu"
assignmentType = "MOST_FREQUENT"
priorityField = "NONE"
cellSize = "0.035714286"
# Execute ExtractValuesToPoints
saveRaster = arcpy.PointToRaster_conversion( filename2, value, outRaster2, assignmentType, priorityField, cellSize)
print " "
print ":o) End Processing
print arcpy.GetMessages()
my point shp file, attribute table...[ATTACH=CONFIG]24481[/ATTACH]i got this errorTraceback (most recent call last):
File "C:\Users\Administrator\Desktop\arcpy\convert", line 33, in <module>
File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\conversion.py", line 1772, in PointToRaster
raise e
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000728: Field RasterValu does not exist within table
ERROR 000840: The value is not a Raster Dataset.
ERROR 000840: The value is not a Raster Catalog.
Failed to execute (PointToRaster).
