Hi Carlo,No, this functionality is not available in ArcCatalog. I suggest you vote for this functionality on Ideas.arcgis.com:Idea: Add a utility or tool to create, edit and analyze the geodatabase schemaHope this helps,
Is there a way in Catalog now to create the database as a diagram (a la Visio)?
1) We are in the conceptual stage of building file geodatabases. With moving to SDE & SQL on the horizon, what considerations should I be taking in constructing my geodatabases?
Do I run the risk of having to redesign my entire geodatabase from scratch once we move to SQL?
Can relationships and topology be built between datasets?
Can a dataset have both topology & geometric networks?
Are there limits to how many feature classes can be in a given dataset?
The Geodatabase Diagrammer links posted above are for past versions of ArcGIS, is this ability still available for Arc 10?
... but I would like the ability to use Excel and Access for editing, querying, reports, forms, etc. so decided to go with the personal geodatabase. Is this an acceptable approach?
Does this mean I have to create another parallel geodatabase with the same structure, or can I somehow create "folders" within the same geodatabase, one to contain Smallville data, and another for Gotham?
