Does anyone know how to use the rotate editing tool in ArcGIS Pro to rotate a feature by an exact degree? This can be done in ArcMap and I can't figure out how to do this in pro. In ArcMap to achieve this you do the following.
- Click the Rotate tool
on the Editor toolbar. - Click anywhere on the map and drag the pointer to rotate the feature to the desired orientation. To specify the exact degree of rotation, press the A key, and type the number of degrees. The angle is applied relative to the current orientation. A positive number rotates the feature to the right; a negative number rotates it to the left. Angular units are determined by the angular or direction units setting on the Units tab of the Editing Options dialog box.
I cannot find this functionality in ArcGIS Pro.
