We are in the process of setting up several SQL Server Geodatabases; and, are faced with IT restrictions at the SQL Server security level. Namely, no database/mixed-mode authentication. All connections must come via Active Directory.
The approach we would like to take, given these restrictions, is as follows:
For the SDE geodatabase owner:
1. At the instance level, grant an AD group access to the instance.
2. At the db level, map that AD group to the sde user/sde schema in the db/gdb.
Active Directory users could then be mapped to the AD group and administer the geodatabase. If their role changed, they could be removed from the AD group.
