Is there a way in workflow manager to change the ended date of a job? We have a bunch that need to be entered for jobs already complete, but I would like the ended date to be corrected once they are entered.
Hi, Thomas, the ended date attribute cannot be edited in the Workflow Manage client. However you could edit the END_DATE values for the desired jobs as needed in the JTX_JOBS table in the Workflow Manager database. This would solve your issue even though making changes directly to a WMX table is not something we normally recommend. If you need to edit the END_DATE values frequently, you could also create a script to run against the database.
Thanks for the quick reply. That is what I though, but I was hoping I was missing something.
Tom
Hi Meggie,
I think you meant to respond via geonet. Do you have a login setup?
Tope
