Is it possible, can We edit point in Arcpad Application?
Regards,
Raj
If you have seen arcpad have the start editing button. With this you can edit a previous point or line or polygon, and modify the attribute data, or add another point or select the existent points and move or delete them.
When you start the editing session, you need first to select an existing feature, or you can make a new feature inside the map, even with the gps help.
Read the arcpad help
ArcPad Help
ArcPad User Guide
and here the field guide in pdf
http://www.esri.com/~/media/Files/Pdfs/industries/locationservices/pdfs/arcpad-field-users-guide.pdf
I had created custom tool bar in ArcPad using VBSCript to add point and update attributes. Is it possible can We edit attributes after add points. If We can then can you suggest me to do it.
Raj P
I had created the custom tool bar to add point for field surveyor. When adding point I am fine with adding attributes values. I would like to edit the points while entrying a point in the field.
You have to be more specific.
Have you started a new editing session with arcpad with this new feature point..???
Are you working in the office or in the field with your GPS unit with arcpad..???
