searchQueryTask.execute(searchQuery, showSearchResults, errResults);
you could try calling the 'cancel()' method before making another call. The code below is intended to show the general concepts only.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Query State Info without Map</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.4/js/dojo/dijit/themes/claro/claro.css"> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.4"></script> <script type="text/javascript" language="Javascript"> dojo.require("esri.tasks.query"); dojo.require("esri.map"); var queryTask, query; var queryDeferred; function init() { //build query queryTask = new esri.tasks.QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/3"); //build query filter query = new esri.tasks.Query(); query.returnGeometry = false; query.outFields = ["*"]; } function execute(stateName) { // query already running query? if(queryDeferred && (queryDeferred.fired > 0)) { dojo.byId("info").innerHTML = "Query task is already running..."; } else { dojo.byId("info").innerHTML = "Running query task: " + (new Date()).toLocaleTimeString(); //execute query query.text = stateName; queryDeferred = queryTask.execute(query); queryDeferred.then(showResults,showError); } } function execute2(stateName) { // cancel previous query cancelExecute(); dojo.byId("info").innerHTML = "Running query task: " + (new Date()).toLocaleTimeString(); //execute query query.text = stateName; queryDeferred = queryTask.execute(query); queryDeferred.then(showResults,showError); } function showResults(results) { dojo.byId("info").innerHTML = "Preparing results..."; var s = ""; for (var i=0, il=results.features.length; i<il; i++) { var featureAttributes = results.features.attributes; for (att in featureAttributes) { s = s + "<b>" + att + ":</b> " + featureAttributes[att] + "<br />"; } } dojo.byId("info").innerHTML = s; } function showError(error) { dojo.byId("info").innerHTML += dojo.toJson(error); } function cancelExecute() { if(queryDeferred && (queryDeferred.fired > 0)) { queryDeferred.cancel(); dojo.byId("info").innerHTML = "Query task cancelled."; } else { dojo.byId("info").innerHTML = "Query task not running..."; } } dojo.addOnLoad(init); </script> </head> <body> US state name : <input type="text" id="stateName" value="C" /> <input type="button" value="Get Details (not if alreay running)" onclick="execute(dojo.byId('stateName').value);" /> <input type="button" value="Get Details (cancel first)" onclick="execute2(dojo.byId('stateName').value);" /> <input type="button" value="Cancel" onclick="cancelExecute();" /> <br /> <br /> <div id="info" style="padding:5px; margin:5px; background-color:#eee;"> </div> </body> </html>
When you code runs the first time, the queryEvent is null or undefined. So it will almost be certain that you will catch an exception -dojo.stopEvent(undefined);
I think stopping a query complete event does not really service your purpose. It basically tries to stop an already completed query process not an query that is under process. That is probably why it does not working.
Heming, I'm not having any luck with this. Below is the code I'm trying (a modification of the Query No Map sample with the relevant changes highlighted): <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Query State Info without Map</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.4/js/dojo/dijit/themes/claro/claro.css"> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.4"></script> <script type="text/javascript" language="Javascript"> dojo.require("esri.tasks.query"); dojo.require("esri.map"); var queryTask, query; var queryEvent; function init() { //build query queryTask = new esri.tasks.QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5"); //dojo.connect(queryTask, "onComplete", showResults); //build query filter query = new esri.tasks.Query(); query.returnGeometry = true; query.outFields = ["SQMI","STATE_NAME","STATE_FIPS","SUB_REGION","STATE_ABBR","POP2000","POP2007","POP00_SQMI","POP07_SQMI","HOUSEHOLDS","MALES","FEMALES","WHITE","BLACK","AMERI_ES","ASIAN","OTHER","HISPANIC","AGE_UNDER5","AGE_5_17","AGE_18_21","AGE_22_29","AGE_30_39","AGE_40_49","AGE_50_64","AGE_65_UP"]; } function execute(population) { query.where = "POP2007 >" + population; //execute query try { dojo.stopEvent(queryEvent); }catch(e){ console.log("error"); } queryEvent = queryTask.execute(query,showResults); } function showResults(results) { var s = ""; for (var i=0, il=results.features.length; i<il; i++) { var featureAttributes = results.features.attributes; for (att in featureAttributes) { s = s + "<b>" + att + ":</b> " + featureAttributes[att] + "<br />"; } } dojo.byId("info").innerHTML = s; } dojo.addOnLoad(init); </script> </head> <body> Population is greater than: <input type="text" id="population" value="50000" /> <input type="button" value="Get Details" onclick="execute(dojo.byId('population').value);" /> <br /> <br /> <div id="info" style="padding:5px; margin:5px; background-color:#eee;"> </div> </body> </html> Rather than monitoring the query's state in a variable I figured a try/catch statement should do the same thing, right? The problem is that the dojo.stopEvent declaration doesn't seem to have any effect. The NET tab in Firebug shows that the query takes around 2 seconds to execute. Pressing the button a few times quickly shows that the previous processes are not cancelled. Any clues? Cheers, Steve
Hi Derek,Background to this question - I'm trying to keep the UI really simple, so the user doesn't have to worry about typing in a query. A 2-handled dojo slider bar works really well for selecting features between a range, aside from the asynchronous query issue.Filtering on a feature layer may be an option here. I could also use a Submit button which runs the query, rather than running it onChange.Any other suggestions would be very welcome.Cheers,Steve
var inProgress =false; .... var queryEvent =dojo.connect(querytask, "onComplete", querTaskOnComplete); function sliderOnchange(newValue) { // stop passed event if passed event is still in progress if (inProgress ==true) dojo.stopEvent(queryEvent); // start a new query process inProgress =true; ... do your query here... } function querTaskOnComplete(featueSet) { ....do you post query action here.... //reset inProgress at the end of the function inProgress =false; }
