I have a general question about how to capture attribute values from a WebMap (using API 4.x) without using click events on the map (this thread #Capture attribute values from a WebMap has an excellent solution using the click event and the hitTest method, but now I need to access attribute values without having to click on the map).
This thread #Access ArcGIS Server database content from JavaScript application has a solution based on QueryTask (API 3.22), but I don't know what this object maps to in API 4.4.
I am also not aware of having access to a REST service associated with this WebMap, and I am not familiar with the ArcGIS framework, but if I have access to a WebMap through the portalItem property, does that mean that I should get access to a REST service too? Is there a way I can access the attribute values without setting up a REST service?
I would also like to avoid using the FeatureLayer object since my web application resides in a different domain than the ArcGIS server and when I try to use FeatureLayer I get a CORS error.
I apologize for the vagueness but thanks for your help,
LA
I am also a bit confused why
console<SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">.</SPAN><SPAN class="" style="color: #d74444; border: 0px; font-weight: inherit;">log</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">(</SPAN><SPAN class="" style="color: #669900; border: 0px; font-weight: inherit;">"Num WebMap Layers: "</SPAN><SPAN class="" style="color: #a67f59; background: rgba(255, 255, 255, 0.5); border: 0px; font-weight: inherit;">+</SPAN>webmap<SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">.</SPAN>layers<SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">.</SPAN>length<SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">)</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">;</SPAN>
displays zero for number of WebMap layers, I guess they are embedded differently into the WebMap?
My current code:
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/WebMap"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/domReady!"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>MapView<SPAN class="punctuation token">,</SPAN> WebMap<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">/************************************************************
* Creates a new WebMap instance. A WebMap must reference
* a PortalItem ID that represents a WebMap saved to
* arcgis.com or an on-premise portal.
************************************************************/</SPAN>
<SPAN class="keyword token">var</SPAN> webmap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">WebMap</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
portalItem<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// autocasts as new PortalItem()</SPAN>
id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"7faf8d05df114f8082411414382c69d3"</SPAN>
<SPAN class="comment token">//id: "65de4dd5bbfb4c0dbac85d395052bee3" // Speed Studies Web Map</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
* Set the WebMap instance to the map property in a MapView.
<SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
map<SPAN class="punctuation token">:</SPAN> webmap<SPAN class="punctuation token">,</SPAN>
container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewMap"</SPAN>
view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitTest</SPAN><SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>results<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>results<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"Type"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>results<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>results<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"Type"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="operator token">!=</SPAN><SPAN class="string token">"B"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"#startPt"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">css</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"background-color"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"red"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"#startPt"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">css</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"background-color"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"transparent"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
