Split line at point tool in not working when i m splitting Arc FM features.
I meant that output is not as per it suppose to be.
After I ran the tool, the result is like lines get split at wherever it find the intersection, I mean it splits at each junction.
The database I use is FGDB. ArcGIS 10.2.1
I hope I have answered all your questions.
In what way doesn't it work? Tool greyed out, throws an error?
What sort of db are you using - enterprise, fgdb....
Arc version?
If its an enterprise db, is the data versioned?
Hey Dan,
Thanks for ur perusal to my query.
I am using the tool from the ArcToolbox. I m splitting Distribution Pipe at point feature. All points are snapped to the Distribution Pipe.
Procedure:
Input Feaures as Distribution Pipe.
Point Feature as Non-Controllable Device
Output feature class: Saved it in the same dataset with a different name.
I am unsure of any other details I could share with you that will help you to resolve the same.
Vaibhav
Do you have any more details? ie procedure to split the features? All features of this type? Only a particular feature? etc
