So i have a utilities folder with a common.js that contains a bunch of helper methods. Pre AMD it looked like. NO idea how to migrate to AMD. THANKS!dojo.provide("utilities.common");
utilities.common.getType = function(value) {
var type = "config.json";
switch (value) {
case "test":
type = "config-test.json";
break
case "landdevelopment":
type = "config-landdevelopment.json";
break
case "utilitiesinfrastructure":
type = "config-utilitiesinfrastructure.json";
break
default:
return type;
utilities.common.getFormattedServiceType = function(value) {
var type = "Property Locator";
var newValue = (value.replace(".json", "")).replace('config-', '');
switch (newValue) {
case "test":
type = "Test";
break
type = "Land Development";
break
type = "Utilities Infrastructure";
break
default:
return type;
utilities.common.getAllNamedChildDijits = function(id) {
// Gather all child widgets
var w = null;
var children = null;
widgets = {};
w = dojo.query("[widgetId]", dojo.byId(id));
children = w.map(dijit.byNode);
children.forEach(function(item, idx) {
if (item.name) {
widgets[item.name] = item;
return widgets;
