I was recently making edits to the startup.bat file in an attempt to run the file over a network. It didn't work, and now that I've reverted the file to the correct code, all of my applications do not show in the web browser UI. The data for the applications are still visible in the "\server\apps\" folder, but none of them show up in the browser window.
I believe that a simple fix would be to re-import the missing applications. However, I wanted to ask if anybody knows how to correct this problem. I provided the details of my edits to the serverPath variable below:
# The original code used in the .bat file. The variable is located close to the top of the batch file.
SET serverPath="C:\WebAppBuilderForArcGIS\server"
# "C:\WebAppBuilderForArcGIS\" is mapped to "Z: as a Network Drive" on my coworker's machine.
# Since UNC paths throw errors in batchfiles, I tried to Map the drive instead. (ex: \\[MachineName]\c$)
SET serverPath="Z:\server"
# When the WAB failed to load correctly, I reverted the files to their original states, and the issues started.
(PS: This is my first time posting on the GeoNet Community, so some feedback on how to format posts would be appreciated.)
