i got the this error message.what's wrong to me?Traceback (most recent call last): File "C:/Users/Administrator/Desktop/arcpy/convert", line 36, in <module> saveRaster = arcpy.PointToRaster_conversion( filename2, "RASTERVALU", outRaster2, "MOST_FREQUENT", "NONE", cellSize) File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\conversion.py", line 1772, in PointToRaster raise eExecuteError: ERROR 999999: Error executing function.Failed to execute (PointToRaster).
# Import arcpy module
import arcpy, os
from arcpy import env
from arcpy.sa import *
# Set environment settings
arcpy.env.workspace = "C:/py2/extract"
OutputFolder2 = "C:/py2/result"
# Loop through a list of files in the workspace
RasterFiles2 = arcpy.ListFeatureClasses()
print "POINT TO RASTER"
print RasterFiles2
print " "
# Set local variables
for filename2 in RasterFiles2:
print "Processing: {0}".format(filename2)
outRaster2 = os.path.join(OutputFolder2, filename2 + "_4x")
valField = "RASTERVALU"
assignmentType = "MOST_FREQUENT"
priorityField = "NONE"
cellSize = "0.035714286"
# Execute ExtractValuesToPoints
saveRaster = arcpy.PointToRaster_conversion( filename2, valField, outRaster2, assignmentType, priorityField, cellSize)
print "done "
print arcpy.GetMessages()
