I'd like to also bind Layer.Description or Description (see my xaml).None of these work. I also notice that Description is never populated.I see it in the arcgis/rest/services reference but this does not get populated..
Note: I was debugging the legend refresh event handler and perusing the e.LayerItemto try and find Description with my value....Do you know if this is available via the Object Model?
string[] layerIDs = { "wellsgeneral", "bitatg", "completion", "onetrax", "dandm", "dtandr" };this.googWellLayerList.LayerIDs = layerIDs;this.googWellLayerList.Refreshed += new EventHandler<Legend.RefreshedEventArgs>(googWellLayerList_Refreshed);this.googWellLayerList.Refresh();
<CheckBox Content="{Binding Label}" IsChecked="{Binding IsEnabled, Mode=TwoWay}" Checked="CheckBox_Checked" />
I'd like to give them some nice display names without messing with the binding behavior....
Unable to cast object of type 'Microsoft.Expression,DesignModel,DocumentModel.DocumentPrimitiveNode to typeMicrosoft.Expression.DesignModel,DocumentModel.DocumentCompositeNode'.The sample you specified lists layer ids this way. What can I do to fix this?
I changed it to if (layerItemVM.Label.ToUpper().Contains("LABEL"))removeLayerItemVM = layerItemVM;Is this correct?
if (e.LayerItem.LayerItems != null) { var toDelete = e.LayerItem.LayerItems.Where(item => item.Label.ToUpper().Contains("LABEL")).ToList(); foreach (var item in toDelete) e.LayerItem.LayerItems.Remove(item); }
