What I'm trying to do is capture the value of each pixel in a raster, but I'm only interested in each unique value per row.In the 10 x 10 example below, the first row pixel values that would be listed are: 191,192,188,190,181,203,183,192,203,195where the second row would have 8 unique values because 181 and 172 are repeated: 181,187,172,186,182,189,161,208[ATTACH=CONFIG]30468[/ATTACH]I suppose ideally the output would be like this:row:values0:191,192,188,190,181,203,183,192,203,1951:181,187,172,186,182,189,161,208I'm stuck with 10.1 at the moment so I'll have to work within those parameters.
import arcpy import numpy raster = 'path\to\raster' output = 'the\output.file' data = arcpy.RasterToNumPyArray(raster).tolist result = open(output, 'w') rowNum = 0 for row in data: unique = set(row) result.write('%s:'%rowNum) line = '' for val in unique: line += '%s,'%val line = line[:-1] + '\n' #eliminates a trailing comma result.write(line) rowNum += 1 result.close()
import arcpy raster = 'path\to\ASCIIraster.asc' output = 'the\output.file' ASCIIData = open(raster, 'r') OutData = open(output, 'w') rowNum = 0 for line in ASCIIData: values = line.split() writeLine = '%s:'%rowNum try: test = int(values[0]) #This will fail for the headers unique = set(values) #All strings already for val in unique: writeLine += val + ',' writeLine = writeLine[:-1] + '\n' #eliminates a trailing comma OutData.write(writeLine) rowNum += 1 #Has to be here because we don't increment for the header except ValueError: pass #Pass because we are skipping the text header OutData.close()
import arcpy raster = arcpy.Raster("image.tif") array = arcpy.RasterToNumPyArray(raster) (height, width)=array.shape for row in range(0,height): for col in range(0,width): print str(row)+","+str(col)+":"+str(array.item(row,col))
