Hi Kristen,They main issue with which we would like to focus on is that for us the Threshold Trade Area analysis does not work (Error messages) when when clicking on the Threshold Drive Times method and utilizing custom .bds files in Business Analyst 10. We have had this issue in the past and contacted the ESRI Support Services (Esri Incident #1020049). The technician (Matthew P) determined that this issue was a bug and that Threshold trade areas by drive time do not work in Business Analyst 10.Here is his response: ________________________________________________________________________________________________________So I have tested with all BA service packs and different inputs and outputs and have determined this to be a bug. Threshold trade areas by drive time do not work in Business Analyst 10. I have marked the severity as high and submitted the request to the developers. [#NIM079258 Business Analyst threshold trade area using Threshold Drive time fails everytime. "Failed to build the rings..." ]_________________________________________________________________________________________________________What we would like to know is if this bug has been fixed with a solution to the issue? Or is this issue still being investigated?Thank you for you help,Phillip
Hello Everyone,I am having trouble with running a Threshold Trade Area analysis utilizing custom .bds files in Business Analyst 10. I am creating the .bds files by inputting my custom block group data from a shapefile. I am not having trouble actually creating the .bds files as the files do include all of our custom block group data in the Attribute Table, but when I try to utilize those files to run a Threshold Trade Area Analysis using Threshold Drive Times the program either freezes and goes �??Not Responding�?? or I receive the error 080256 (everything works when running the analysis using Standard Threshold Rings). My first question is if there are currently any issues/bugs with the utilization of custom .bds files when running analyses? Also could this issue be a license agreement problem between BA and ArcGIS? Business Analyst is updated to SP3 and ArcGIS is updated to SP4. Is there a certain Service Patch which ArcGIS needs to be set too for Business Analyst to work properly?Another issue I am having is that my custom .bds files which I have previously created in BA9.3.1 running on Windows XP are not visible in ArcCatalog when viewing in BA10 running on Windows 7. Would the difference in operating system have anything to do with the visibility of the .bds files? I ask this because prior to updating to BA 10 we were running BA9.3.1 on Windows 7 and the .bds files created then are visible.Thanks,Phillip
