Hi Jason,
[BUG-000104266 : Unable to Print when including graphical layer generated from Incident Analysis Widget in Portal 10.5 Web AppBuilder]
Hopefully it gets fixed in 10.5.1
-Bill
Did you get a solution from Esri? I just ran into the same problem running Portal 10.5.
I opened a case with ESRI support for this 10.5 issue.
Thank you for posting this issue.
I just hit the same issue with Portal for ArcGIS 10.5
Do you know a fix for it?
Steven White seems to have the correct answer.
I had the same problem printing graphics layers (and feature layers) that had graphics assigned using RGB colors.
I wanted to use RGB so I could set an alpha value to the graphic.
As a work around I set the colors using hexadecimal color and just set an opacity value on the graphics layer and / or feature layer.
