Hi
I'm trying to figure out how to extract a value of records returned from a Select by Location model I built.
Here's the process (in bold, the parameters name as defined in the model its picture is attached to this post):
- The process starts with the execution of a 'Select by Location' tool, in which the user select a certain feature from a defined feature layer, (AttachGeometry) using a featureset (InteractiveSelect)- this part of the tool goes fine easily as a selection is evident after the model finishes its run.
- I then use the 'Iterate Field Values' tool over the returned feature(s) (SelectedLocations), aiming at garbing the unique value (DocID) for a specific field - this is where, as I suspect, my problem, as no value is 'transferred' to the next step of the process.
- This value is then transferred (as In line parameter, as can be see in the picture attached to this post) to a 'Select by Attribute' tool, for retrieving the matching records in another table, based on this value
- The process ends when the selected records are exported as a new table (Results).
As noted above, the 'Iterate Field Values' returns no values, thus no selection is made when the 'Select by Attribute' section of the model is executed - a new table is created, with no records in it. I receive the following message for the exported records: 'WARNING 000117: Warning empty output generated'.
Any help will be appreciated.
Gal
