In upgrading my application to version 3.7 of the api, I've run into what I believe is a bug. When I try to connect to the layers-add-result event for my map, I try to use the dojo/on amd method. My code for that is:on(map, "layers-add-result", function(e) { var toc = new agsjs.dijit.TOC({ map: map, layerInfos:legendLayers }, 'legendDiv'); toc.startup(); });That returns an error "TypeError: Cannot read property 'tagName' of undefined ". When I try using the old dojo.connect method, though, everything works. My code using the old dojo.connect is:dojo.connect(map,'onLayersAddResult', function(results){ var toc = new agsjs.dijit.TOC({ map: map, layerInfos:legendLayers }, 'legendDiv'); toc.startup(); });According to the documents, version 3.7 is using dojo version 1.9.1, which should certainly support the dojo/on functionality. What, if anything, am I doing wrong. If I'm not doing anything wrong, how do I file a bug report?
