Whats is the way (if exists) to get the geometry type (point, line, polygon) of a MapImageLayerSublayer? I'm using js API 4.5. The way i'm doing is going on the server again and geting the json of the layer to get the geometry type
OK, from you post I was not sure if you were aware of the REST Layers endpoint for getting all map service layers or if you were doing a server round trip for each layer. As I mentioned there is not current way to do this without a service trip.
Rodrigo,
I am not aware of any property to do this in 4.5 but you can just take the url of the whole MapService and append "layers" to the end of the url and do an esriRequest and parse the results json for layers.geometryType.
Here is a sample:
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta charset<SPAN class="operator token">=</SPAN><SPAN class="string token">"utf-8"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1,maximum-scale=1,user-scalable=no"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>MapImageLayer <SPAN class="operator token">-</SPAN> <SPAN class="keyword token">set</SPAN> renderers on sublayers <SPAN class="operator token">-</SPAN> <SPAN class="number token">4.4</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F4.4%2Fesri%2Fcss%2Fmain.css" target="_blank">https://js.arcgis.com/4.4/esri/css/main.css</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F4.4%2F" target="_blank">https://js.arcgis.com/4.4/</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN> html<SPAN class="punctuation token">,</SPAN> body<SPAN class="punctuation token">,</SPAN> #viewDiv <SPAN class="punctuation token">{</SPAN> padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN> <SPAN class="string token">"esri/Map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/MapImageLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/renderers/SimpleRenderer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/SimpleMarkerSymbol"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/SimpleLineSymbol"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/SimpleFillSymbol"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/request"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/domReady!"</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN> Map<SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">,</SPAN> MapImageLayer<SPAN class="punctuation token">,</SPAN> SimpleRenderer<SPAN class="punctuation token">,</SPAN> SimpleMarkerSymbol<SPAN class="punctuation token">,</SPAN> SimpleLineSymbol<SPAN class="punctuation token">,</SPAN> SimpleFillSymbol<SPAN class="punctuation token">,</SPAN> esriRequest <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">/***************************************************************** * Create renderers for each sublayer: cities, highways, states *****************************************************************/</SPAN> <SPAN class="keyword token">var</SPAN> citiesRenderer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleRenderer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> symbol<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleMarkerSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> size<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">,</SPAN> color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"white"</SPAN><SPAN class="punctuation token">,</SPAN> style<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"circle"</SPAN><SPAN class="punctuation token">,</SPAN> outline<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.5</SPAN><SPAN class="punctuation token">,</SPAN> color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"gray"</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Cities"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> statesRenderer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleRenderer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> symbol<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleFillSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> style<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"none"</SPAN><SPAN class="punctuation token">,</SPAN> outline<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.5</SPAN><SPAN class="punctuation token">,</SPAN> color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"gray"</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"State boundaries"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> highwaysRenderer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleRenderer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> symbol<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> style<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"none"</SPAN><SPAN class="punctuation token">,</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.7</SPAN><SPAN class="punctuation token">,</SPAN> color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"white"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Interstate highway"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">/***************************************************************** * Create a MapImageLayer instance pointing to a Map Service * containing data about US Cities, States and Highways. * Define sublayers with visibility for each layer in Map Service. *****************************************************************/</SPAN> <SPAN class="token function">esriRequest</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fsampleserver6.arcgisonline.com%2Farcgis%2Frest%2Fservices%2FUSA%2FMapServer%2Flayers%3Ff%3Djson" target="_blank">https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/layers?f=json</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> responseType<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"json"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> response<SPAN class="punctuation token">.</SPAN>data<SPAN class="punctuation token">.</SPAN>layers<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>layer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">info</SPAN><SPAN class="punctuation token">(</SPAN>layer<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">+</SPAN> <SPAN class="string token">": "</SPAN> <SPAN class="operator token">+</SPAN> layer<SPAN class="punctuation token">.</SPAN>geometryType<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> layer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapImageLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fsampleserver6.arcgisonline.com%2Farcgis%2Frest%2Fservices%2FUSA%2FMapServer" target="_blank">https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN> sublayers<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN> <SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN> renderer<SPAN class="punctuation token">:</SPAN> statesRenderer<SPAN class="punctuation token">,</SPAN> opacity<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.4</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN> renderer<SPAN class="punctuation token">:</SPAN> highwaysRenderer<SPAN class="punctuation token">,</SPAN> opacity<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.8</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> renderer<SPAN class="punctuation token">:</SPAN> citiesRenderer<SPAN class="punctuation token">,</SPAN> opacity<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.6</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">/***************************************************************** * Add the layer to a map *****************************************************************/</SPAN> <SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"dark-gray"</SPAN><SPAN class="punctuation token">,</SPAN> layers<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>layer<SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN> zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">6</SPAN><SPAN class="punctuation token">,</SPAN> center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">83.114</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">36.921</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewDiv"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Did the sample I posted help?
I was already doing it that way, I'm wondering if is possible do do that without another roundtrip to the server. Thank you for your reply
Is this still true in 2024? You have to manually request the URL and parse it, even if you already have a MapImageLayer object?
