Is this possible? I can use the UniqueValueRenderer with one integer field, but I can't get it to work with two. The renderer really has about 50 values, but I've only included one below so you get the idea:
<SPAN class="keyword token">var</SPAN> fineRenderer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">UniqueValueRenderer</SPAN><SPAN class="punctuation token">(</SPAN>defaultSymbol<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Overstory"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Understory"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">":"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
fineRenderer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addValue</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">11000</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">11000</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleFillSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleFillSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">217</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>
I cannot figure out what I'm doing wrong. I'm specifying null for the third attribute field and then specifying the delimiter. My FeatureLayer has both "Overstory" and "Understory" fields. I don't know what the deal is. Do I need to put quotes around 11000:11000? I don't know if that'd work because the fields are integers, not strings. Do I need to try putting it in brackets like [11000:11000] or something? I'm at a loss here.
