I am trying to automatically calculate a date field. What I would like to do is take a permit date and add 180 days to calculate an expiration date. I added a date field for the final calculation. I open the field calculator and write the expression. The expression verifies correctly but when I calculate the field I get errors. I tried several different calculations to see if any of them would work. Below is an example of a calc I did to extract a date. Again, the expression verified correctly but then this error popped up when I calculated the field.
From the error message, it appears you're using the extract function. This function, I believe, returns a number. If you are trying to assign this value to a date field, you'll get a field type mismatch of trying to calculate a number into a date field.
If your goal is to simply add 180 days to a date in a field and assign it to another field, you can form an expression like this:
[PermitDate] + 180
Under normal circumstances, this would yield a new date 180 days into the future. HOWEVER, THERE IS A BUG in AGOL with date addition, where it doesn't work. Subtraction, however works. So try this expression
[PermitDate] - -180
Where you subtract negative 180.
Mike
Thank you Mike. Your suggestion of adding a negative did work in Desktop, but it did not work in ArcGIS online. This still solves my problem with the calculation and works for me.
Veronica
Regarding the bug in AGOL when calculating a date field, I found that when I turned off the sync setting, a calc operation worked properly. When sync was on, the calc would fail.
--Jeff
