hi Ferat Çağlar,did you find a solution? I used: asc2DSSGrid INPUT=pre_19700101.asc DSS=Pre.dss PATHNAME=/UTM36/Ceyhan/Precip/01JAN1970:0000/01JAN1970:2400/PROJECTED/ GRIDTYPE=UTM ZONE=36N DUNITS=mm DTYPE=PER-***
but I didn't see any dss file?
any help
many thanks
Sorry for the late response. I do not have experience in what you are doing.
Mark
Sikanar,
I have not converted raster data to dss before, so I don't think I can help you. Sorry.
I'm having difficulty while trying to convert ascii to dss. I'm using asc2dssGrid.exe tool in order to do that.
below is my command line input
asc2DSSGrid INPUT=pre_19700101.asc DSS=Pre.dss PATHNAME=/UTM36/Ceyhan/Precip/01JAN1970:0000/01JAN1970:2400/PROJECTED/ GRIDTYPE=UTM ZONE=36N DUNITS=mm DTYPE=PER-CUM
and below is the header file of my ascii input
ncols 40nrows 45xllcorner 571919.145856yllcorner 3926307.6104104cellsize 10000NODATA_value -9999
and below is the output of command line output of asc2dssGrid.exe
= = = GridInfo = = =gridType: UNKNOWNinfoSize: 124gridInfoSize: 124startTime: 7 January 1970, 00:00endTime: 7 January 1970, 24:00dataUnits: mmdataType: PER-CUMlowerLeftCellX: 0lowerLeftCellY: 0numberOfCellsX: 40numberOfCellsY: 45cellSize: 10000
It appears to be reading grid values correctly since I get the max min values same as my input. However, definitions of gridtype and LowerLeftCellX-Y are wrong (0 in this case) or remain as UNKNOWN.
Any advice is appreciated!
Hi Sikandar Ali !
Did you find a way to do the conversion?
I have prepared CN grid on arcgis (using HEC-geoHMS) but I can t find a way to convert raster to HEC-DSS..
Hi Mark,
If you can tell me how to create SHG grid for other projection rather than Albers Equal Area Conic that would be really helpful.
check this page and the tool..
HEC-GridUtil Features
Hi Dear, i am Alexandar from Pakistan and working on HEC-HMS. Actually i need your help, I want to convert Raster Satellite Rainfall data to DSS for input to HEC HMS. Kindly guide me how to do this. If you have these tools then kindly send me here. sikandaruaf@gmail.com
asc2dssgrid.exe
DSSTS (time series) tool
Dear, If you have the solution for raster to dss conversion then kindly guide me, thanks
I am trying to import TimeSeries data from DSS to GDB. It works fine, but I would like to import data such STORAGE which is undefined in ApUtilities Framwork Config XML. I added STORAGE variable and connected UNITS to XML. Tool works, but output is empty. Please, do You have any experience with importing/exporting undefined. Is possible to do it so simply?
I am using ArcGIS 10.2.1 with lastest ArcHydro, GeoHMS and HMS.
I inserted that: "<Variable Name="STORAGE" CPART="STORAGE" DTYPE="INST-VAL" />" and "<Unit Name="1000 m3" DSSUnit="1000 M3" />"
Thank You for Answer!
I am trying to convert raster layers into DSS files to be used in the HEC-HMS models. The tool in arcHydro converts time series layres into DSS files, not raster layers. Is there a program or method to convert from raster to DSS?Thank you.
