<!doctype html> <html lang="en"> <head> <meta charset="utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title></title> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/dojo/dijit/themes/tundra/tundra.css"> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/esri/dijit/css/Popup.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map{ margin: 0; padding: 0; } </style> <script>var dojoConfig = { parseOnLoad: true };</script> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5"></script> <script> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); dojo.require("esri.tasks.query"); dojo.require("esri.dijit.Popup"); var map; function init() { var dynSvc = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer",{"opacity":0.5}); var ext = new esri.geometry.Extent({"xmin":-97.968323,"ymin":32.405333,"xmax":-86.220025,"ymax":37.006985,"spatialReference":{"wkid":4269}}); var popup = new esri.dijit.Popup(null, dojo.create("div")); map = new esri.Map("map", { "extent": ext, "infoWindow": popup }); map.addLayer(dynSvc); dojo.connect(map, 'onClick', queryCounties); dojo.connect(map, 'onLoad', function() { dojo.connect(dijit.byId('map'), 'resize', map, map.resize); }); } function queryCounties(e) { // build an extent around the click point var pad = map.extent.getWidth() / map.width * 3; var queryGeom = new esri.geometry.Extent(e.mapPoint.x - pad, e.mapPoint.y - pad, e.mapPoint.x + pad, e.mapPoint.y + pad, map.spatialReference); var q = new esri.tasks.Query(); q.outSpatialReference = {"wkid": 4269}; q.returnGeometry = true; q.outFields = ["NAME", "STATE_FIPS", "CNTY_FIPS"]; q.geometry = queryGeom; var popupTemplate = new esri.dijit.PopupTemplate({ title: "{NAME}", fieldInfos: [ { fieldName: "CNTY_FIPS", visible: true, label: "County FIPS: " }, { fieldName: "STATE_FIPS", visible: true, label: "State FIPS: " } ] }); var qt = new esri.tasks.QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/3"); var def = qt.execute(q); def.addCallback(function(result) { return dojo.map(result.features, function(f) { f.setInfoTemplate(popupTemplate); return f; }); }); // use the deferred returned from the query task to set // the popup features map.infoWindow.setFeatures([def]); // show the popup map.infoWindow.show(e.screenPoint, map.getInfoWindowAnchor(e.screenPoint)); } dojo.ready(init); </script> </head> <body class="tundra"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width: 100%; height: 100%; margin: 0;"> <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"> </div> </div> </body> </html>
Here's an example of using a popup with a dynamic map service:JSFiddle: http://jsfiddle.net/swingley/Bkswj/This sample is using a query task to get features that intersect a click point and then using the deferred returned by the query task to set features for the map's popup.If you're underlying data is time-enabled, use a timeExtent property on your query to query by time.
Dear Derek,Could you please elaborate on how can I use a timeExtent property to query by time. I have a timeSlider and want to be able to connect the popup with the current time extent. Do you have a sample with dynamic service and a timeslider? It would help a lot.Thanks,Anna
