I realize this is a little old, but I did write a variant of spatial join for the use case you are discussing. It can integrate into model builder workflows and the python sample is there.
ArcNumerical-Tools/NumericalSpatialJoin.py at master · Holisticnature/ArcNumerical-Tools · GitHub
Let me know if you have any questions.
import arcpy arcpy.env.overwriteOutput = True targetFeatures = r'C:\data.gdb\bufferLayer' joinFeatures = r'C:\data.gdb\censusTracts' outputFeatures = r'C:\data.gdb\spatialJoinOutput' # create a list of fields to sum fieldNamesToSum = ['CENSUS_FIELD_TO_SUM_1', 'CENSUS_FIELD_TO_SUM_2'] # create the field mapping object fieldMappings = arcpy.FieldMappings() # populate the field mapping object with the fields from both feature classes fieldMappings.addTable(targetFeatures) fieldMappings.addTable(joinFeatures) # loop through the field names to sum for fieldName in fieldNamesToSum: # get the field map index of this field and get the field map fieldIndex = fieldMappings.findFieldMapIndex(fieldName) fieldMap = fieldMappings.getFieldMap(fieldIndex) # update the field map with the new merge rule (by default the merge rule is 'First') fieldMap.mergeRule = 'Sum' # replace with the updated field map fieldMappings.replaceFieldMap(fieldIndex, fieldMap) arcpy.SpatialJoin_analysis(targetFeatures, joinFeatures, outputFeatures, "JOIN_ONE_TO_ONE", "KEEP_ALL", fieldMappings, "INTERSECT", "", "")
