Hi everbody
Installing a geometric network without tolerance is dry without trouble but when I give 0.01 snapping tolerance, I get the following error. (The same problem persists even with different tolerance values.)
I have ArcGIS 10.4.1
There are many objects on the available data that are very close together but are not snapable.
Like this
if the coordinate system is projected and you are trying to edit it, why are you setting such a tiny snap tolerance? snap tolerance for editing is in the units of the coordinates
EDITS to add
http://desktop.arcgis.com/en/arcmap/latest/manage-data/geometric-networks/editing-geometric-network-features-about-editing-g.htm
Thanks for answer
I tried a lower tolerance but I got the same error. (I tried many tolerance values like this, 0.000001, 0.000010, 0.000100. 0.001000, 0.010000, 0.100000)
I have a custom coordinate system like this.
TM_ITRF_30Authority: Custom
Projection: Transverse_MercatorFalse_Easting: 500000.0False_Northing: 0.0Central_Meridian: 30.0Scale_Factor: 1.0Latitude_Of_Origin: 0.0Linear Unit: Meter (1.0)
Geographic Coordinate System: ITRFAngular Unit: Degree (0.0174532925199433)Prime Meridian: Greenwich (0.0)Datum: D_GRS_1980 Spheroid: GRS_1980 Semimajor Axis: 6378137.0 Semiminor Axis: 6356752.314140356 Inverse Flattening: 298.257222101
If the geometry hasn't been repaired the only other link that has this error is for arcmap 10.3.. for a seemingly unrelated issue
http://support.esri.com/en/download/1839
What is the coordinate System? If it's a Geographic Coordinate System (i.e., units are in Decimal Degrees), go for a much lower tolerance like 0.000001.
