I'm having the same issue when running my python script. It connects the layers fine, then immediately removes them.Is this a known bug?
import arcpy mxd = arcpy.mapping.MapDocument("CURRENT") newSdePath = r"Database Connections\My Connection.sde" for df in arcpy.mapping.ListDataFrames(mxd): for lyr in arcpy.mapping.ListLayers(mxd, "", df): lyr.replaceDataSource(newSdePath, "SDE_WORKSPACE", lyr.datasetName, False) arcpy.RefreshTOC() arcpy.RefreshActiveView() mxd.save() del mxd
import arcpy mxd = arcpy.mapping.MapDocument("CURRENT") newSdePath = r"Database Connections\My Connection.sde" for df in arcpy.mapping.ListDataFrames(mxd): for lyr in arcpy.mapping.ListLayers(mxd, "", df): if (lyr.supports("DATASOURCE") and lyr.supports("datasetName")): lyr.replaceDataSource(newSdePath, "SDE_WORKSPACE", lyr.datasetName, False) arcpy.RefreshTOC() arcpy.RefreshActiveView() mxd.save() del mxd
import arcpy, os mxd = arcpy.mapping.MapDocument("CURRENT") newSdePath = r"Database Connections\My Connection.sde" oldSdePath = r"Database Connections\My Old Connection.sde" for df in arcpy.mapping.ListDataFrames(mxd): for lyr in arcpy.mapping.ListLayers(mxd, "", df): if (lyr.supports("DATASOURCE") and lyr.supports("datasetName")): tempDataSetPath, tempDataSet = os.path.split(lyr.dataSource) tempDataSetPath, tempDataSetClass = os.path.split(tempDataSetPath) if lyr.dataSource == os.path.join(oldSdePath, tempDataSetClass, lyr.datasetName): lyr.replaceDataSource(newSdePath, "SDE_WORKSPACE", lyr.datasetName, False) arcpy.RefreshTOC() arcpy.RefreshActiveView() mxd.save() del mxd
Hi Christian,as far as I understood the "CURRENT" option is basically meant to be used from within the python-Window.Try to parse the full mxd-Path as an argument into your script and make the document line get thatmxd = arcpy.mapping.MapDocument(r"C:\temp\xxtest.mxd") Havent tried but its worth a try!RegardsGuenter
saveACopy (file_name, {version})
dateSaved
