When running the Fill tool and setting the z limit (trying about 8 different values), then running flow direction the output is NOT as expected...cells with values ranging 1-255."
ExtractByAttributes("flowgrid", "flowgrid", "VALUE NOT IN (1,2,4,8,16,32,64,128)")
SetNull("flowgrid" != 0 and "flowgrid" < 256 and (("flowgrid" & ("flowgrid" - 1)) == 0, "flowgrid")
Has this issue been corrected for 10.1?
NIM-069368 When running the Spatial Analyst > Hydrology > Fill tool and specifying a Z limit, ArcGIS Version 10 SP2 fills less sinks than ArcGIS Version 9.3.1 SP2. Status: ResolvedVersion Fixed: 10.1SP Fixed: 10.0SP4
Hi Richard,This issue has not been resolved yet. ESRI was able to reproduce exactly as occurred with my analysis. A software bug report has been sent in by ESRI support services and I haven't heard anything since it was sent in. The reference number for this bug is NIM069368 just so you know.I searched the fixes in SP3 and didn't see it was included so I'm assuming it will be a while before the fix occurs.Wes
