Jessica This is a very old thread. I'll suggest you create a new Post with all the relevant details.
You should also contact Esri Tech Support if possible, share with them your testing observations and check with them.
I have a similar problem. I have a geometric network in a file geodatabase and the first time I used the domains after making them they worked. The next time I was in the project all domains stopped working. I tried everything--removing the domains from the fields, deleting the domains, re-creating them from tables, re-applying them to the same fields...still won't work. I tried to edit in a whole new mxd too. None of them are on a subtype field, all are appropriate data types for the fields they are assigned (just cause I know people will ask these questions).
It is weird they worked at first than just stopped working. Is this a known bug, perhaps some kind of incompatibility with feature classes in a geometric network?
Greetings- I am having some issues with a select number of domains in a specific feature class. I have a file geodatabase build for my Water Infrastructure system. I have multiple "Domains" built for different fields in different feature classes so editing the attributes is easier. Problem: In my wLaterLine feature class - none of my Domains work. I can go into the feature class in ArcCatalog and reset the domains - open the .MXD the geodatabase is in and still not have any drop downs. I don't have any issues with any other feature classes, just this one. How can I fix this?Thanks
