esri.config.defaults.io.useCors = true; esri.config.defaults.io.corsEnabledServers.push("analysis.arcgis.com"); //esriConfig.defaults.io.proxyUrl = "http://localhost/esriProxy/proxy.ashx?" esri.config.defaults.io.proxyUrl = "http://localhost/esriProxy/"; var server = new ServerInfo({ server: "http://analysis.arcgis.com", tokenServiceUrl: "https://www.arcgis.com/sharing/generateToken" // I saw the below on my esri.id.server //adminTokenServiceUrl: "http://analysis.arcgis.com/arcgis/admin/generateToken" }) var loginDeferred = esri.id.signIn("http://analysis.arcgis.com", server); loginDeferred.then(function (response) { esri.id.registerToken(response); }) $("#searchButton").click(function () { var gp = new Geoprocessor("http://analysis.arcgis.com/arcgis/rest/services/tasks/GPServer/FindNearest"); var params = //skipped for space but I know these are fine gp.submitJob(params, completeCallback); }
<?xml version="1.0" encoding="utf-8" ?> <ProxyConfig allowedReferers="*" mustMatch="true"> <serverUrls> <serverUrl url="http://services.arcgisonline.com" matchAll="true"/> <serverUrl url="http://analysis.arcgis.com" matchAll="true"/> </serverUrls> </ProxyConfig>
if (url.indexOf("utilities-infrastructure")>-1||url.indexOf("utilitiesinfrastructure")>-1) { function myCallbackFunction(ioArgs) { ioArgs.content = ioArgs.content || {}; if (esri.id) { if (esri.id.credentials[0]) { if (esri.id.credentials[0].token) { ioArgs.content.token = esri.id.credentials[0].token; } } } return ioArgs; } esri.setRequestPreCallback(myCallbackFunction); }
Request URL: https://localhost/esriProxy/proxy.ashx?https://analysis.arcgis.com/arcgis/rest/services/tasks/GPServer/FindNearest/submitJob?f=json&analysisLayer={"layerDefinition "You do not have permissions to use this resource."
<?xml version="1.0" encoding="utf-8" ?> <ProxyConfig allowedReferers="*" mustMatch="false"> <serverUrls> <serverUrl url="http://services.arcgisonline.com" matchAll="true"/> <serverUrl url="http://analysis.arcgis.com" matchAll="true"/> </serverUrls> </ProxyConfig> <!-- See https://github.com/Esri/resource-proxy for more information -->
var connectingLines = esriRequest({ url: url, content: { f: "json", token: token} });
