Hi Ryan,Is your raster in a geographic or projected coordinate system? If geographic, please re-project to a projected coordinate system using the Project tool, then run the Slope. If your raster is currently in a projected coordinate system please see the following Web Help:The range of slope values in degrees is 0 to 90. For percent rise, the range is 0 for near infinity. A flat surface is 0 percent, a 45 degree surface is 100 percent, and as the surface becomes more vertical, the percent rise becomes increasingly larger.http://help.arcgis.com/en/arcgisdesk...00v2000000.htm
One thing you need to take care of is that everything is in the same units. If elevation values (Z) are in meters, but you define the Projection (XY) as feet, you will not get the correct slope. This is where the Z Factor comes into play. Are you positive your Z value are in meters?
These stripes look like artifacts produced by some forms of tiled compression followed by projection. This suggests the problem is inherent in the original DEM. Take a close look at it (hillshade it if you can) to verify, then go back to the source to track down where the corruption occurred. If it's in the source, the best way to eliminate the stripes is by constructing a custom spatial filter from the FFT of the original grid (which, unfortunately, is not something ArcGIS can help you do).
Bill is correct, you will need to apply a Fast Fourier Transformation to your DEM. There are several articles describing the striping you are seeing (including from the USGS website).http://ned.usgs.gov/Ned/about.asphttp://seamless.usgs.gov/faq/ned_faq.php#sevenhttp://www.ctmap.com/assets/pdfprojects/destripe.pdf
