I want to create a map having functionality of offline routing and searching in ArcPro what should i need ?
Are you looking for Navigation Maps (Navigator)?
FAQs - Navigator
Which licenses do I need to work with navigation maps?This depends on whether you want to use an Esri-provided navigation map as it is, create your own navigation map with entirely your own data, or modify an Esri-provided navigation map. You may also need additional licenses depending on how much you want to modify an Esri navigation map. The following are the answers to this question based on use case:If you want to use an Esri-provided navigation map as it is, you just need a Navigator for ArcGIS license.If you want to create a navigation map using all your own data, you need a Navigator for ArcGIS license and an ArcGIS Pro license with the ArcGIS Network Analyst.If you want to modify an Esri-provided navigation map by clipping to a custom extent, adding operational layers for visualization, or enabling searching on custom geocoding locators, you need a Navigator for ArcGIS license, an ArcGIS Pro license, and a license to use StreetMap Premium for ArcGIS Desktop HERE.If you want to modify an Esri-provided navigation map by adding custom streets, you need a Navigator for ArcGIS license, an ArcGIS Pro license with the ArcGIS Network Analyst, and a license to use StreetMap Premium for ArcGIS Desktop HERE.
You might like to contact your local Esri distributor for further information.
