Hello! I am an absolute rookie at developing with silverlight and ESRI's Silverlight API (pretty much developing in general!), and I am trying to teach myself how to do all of this... That said, I found the below xaml code from this post regarding hyperlinking support in FeatureDataGrids and I am trying to implement it into my project.http://forums.arcgis.com/threads/10338-Adding-Hyperlink-Support-to-the-FeatureDataGrid-in-Silverlight?highlight=hyperlink+silverlight xmlns:data="clr-namespace:System.Windows.Controls;assembly=System.Windows.Controls.Data"
<esri:FeatureDataGrid x:Name="MyFeatureDataGrid" Height="240" VerticalAlignment="Bottom" AutoGenerateColumns="False"
Map="{Binding ElementName=MyMap}" GraphicsLayer="{Binding Layers[1], ElementName=MyMap}">
<esri:FeatureDataGrid.Columns>
<data:DataGridTextColumn Binding="{Binding type}" Header="Type" />
<data:DataGridTemplateColumn Header="Description">
<data:DataGridTemplateColumn.CellTemplate>
<DataTemplate>
<HyperlinkButton Content="{Binding description}" NavigateUri="{Binding description}" TargetName="_blank" />
</DataTemplate>
</data:DataGridTemplateColumn.CellTemplate>
</data:DataGridTemplateColumn>
</esri:FeatureDataGrid.Columns>
</esri:FeatureDataGrid>Can someone please help me to configure this code snippet for use in my project? I have a map service called BaseMap containing a layer called URL. Inside the layer I want to pull across 2 fields. One is called [pno_1] the other [URL] (this field contains the linking information). I think my issue here is with the binding... Again, I am trying to teach myself how to do all of this so please be gentle!Thank you in advance for your help. Josh.
