Well, at least it didn't work for me just now -- I wonder if this has to do with 64bit and Access Drivers related issues?
There is no direct way to reference an MS Access Table to run thru the TableToTable_conversion method (I didn't notice it in the doc).
import arcpy, os arcpy.env.workspace = os.getcwd() arcpy.TableToTable_conversion('NP.mdb/myTable', 'NFG.gdb', "outTable")
My mistake, I read it as MS Excel...instead of MS Access.
There is no direct way to reference an MS Access Table to run thru the TableToTable_conversion method (I didn't notice it in the doc). Well, at least it didn't work for me just now -- I wonder if this has to do with 64bit and Access Drivers related issues?
get a table from MS ACCESS:http://resources.arcgis.com/en/help/main/10.2/index.html#//001200000027000000
intab = r'C:\TestAccessDB\Testdb.mdb\TestTable' wsout = r'H:\Documents\ArcGIS\Default.gdb' arcpy.TableToTable_conversion(intab, wsout, "WindOUT")
I've been after some help for two days now.. Still have not found and example that will work for me.. Use Py to get a table from MS ACCESS, clip, join and return the result in a new table.Walt.
