Set pFields = New esriCore.Fields
Set pPC = pF.Shape
Set pFLayer = pMxDoc.FocusMap.Layer(0)
Its used to access and manipulate the Points in Multipoints, Paths, Rings, Polylines, Polygons, Triangles, TriangleFans, TriangleStrips, and MultiPatches
Item not found in this collection
Public Sub a() Dim pMxDoc As IMxDocument Set pMxDoc = ThisDocument Dim pFLayer As IFeatureLayer Set pFLayer = pMxDoc.FocusMap.Layer(1) Dim pDS As IDataset Set pDS = pFLayer Dim pFWS As IFeatureWorkspace Set pFWS = pDS.Workspace Dim pFields As IFields Dim pFieldsEdit As IFieldsEdit Set pFields = New esriGeoDatabase.Fields Set pFieldsEdit = pFields Dim pField As IField Dim pFieldEdit As IFieldEdit Set pField = New esriGeoDatabase.Field Set pFieldEdit = pField With pFieldEdit .Length = 10 .Name = "PolylineID" .Type = 1 End With pFieldsEdit.AddField pField Set pField = New esriGeoDatabase.Field Set pFieldEdit = pField With pFieldEdit .Length = 10 .Name = "VertexID" .Type = 1 End With pFieldsEdit.AddField pField Set pField = New esriGeoDatabase.Field Set pFieldEdit = pField With pFieldEdit .Length = 20 .Name = "X_Vertex" .Type = esriFieldTypeDouble End With pFieldsEdit.AddField pField Set pField = New esriGeoDatabase.Field Set pFieldEdit = pField With pFieldEdit .Length = 20 .Name = "Y_Vertex" .Type = esriFieldTypeDouble End With pFieldsEdit.AddField pField Dim pTable As ITable Dim pTmpDS As IDataset Dim pEnumDS As IEnumDataset Dim pWS As IWorkspace Set pWS = pFWS Set pEnumDS = pWS.Datasets(esriDTTable) Set pTmpDS = pEnumDS.Next Do Until pTmpDS Is Nothing If pTmpDS.Name = "output" Then pTmpDS.Delete Exit Do End If Set pTmpDS = pEnumDS.Next Loop Set pTable = pFWS.CreateTable("output", pFields, Nothing, Nothing, "") Dim pFClass As IFeatureClass Set pFClass = pFLayer.FeatureClass Dim pFC As IFeatureCursor Set pFC = pFClass.Search(Nothing, False) Dim pF As IFeature Set pF = pFC.NextFeature Do Until pF Is Nothing Dim pPC As IPointCollection Set pPC = pF.Shape Dim i As Integer i = 1 Dim x As Integer For x = 0 To pPC.PointCount - 1 Dim pRow As IRow Set pRow = pTable.CreateRow pRow.Value(3) = pPC.Point(x).x pRow.Value(4) = pPC.Point(x).Y pRow.Value(2) = i pRow.Value(1) = pF.OID pRow.Store i = i + 1 Next x Set pF = pFC.NextFeature Loop End Sub
