import multiprocessing import csv import arcpy def CalculateOD(stuffPassed): '''Calculate the OD matrix and write the results to a CSV''' ## Generate the input layer. You can read in a saved layer template ## add add the appropriate origins and destinations for this chunk ## Solve the layer ## Call the external Save-to-CSV code or write your own code ## Return the path to the CSV # ---- Main code ---- def main(): ## Do whatever you need to prepare your analysis ODChunks = [] ## Fill your list of OD chunks somehow # Pass this info as inputs to the multiprocessing function. stuffToPass = [] for chunk in ODChunks: if chunk: idx = ODChunks.index(chunk) # I'm passing the chunk index because you can use that to name the output file stuffToPass.append([chunk, idx, OTHERVARIABLES]) # Do the multiprocessing. It could return the paths to the output csvs if you want. pool = multiprocessing.Pool() OutCSVs = pool.map(CalculateOD, stuffToPass) pool.close() pool.join() # Combine the output csvs for CSVFile in OutCSVs: ## Open each CSV using python's csv module ## The first line is probably the field headers, so discard that after the first time ## Dump the rows out into one giant table. if __name__ == '__main__': main()
