"%Ammonia%" I think this is correct.
Using your attachment as reference I can see you take a string variable and check to see what the string is using the "Calculate Value" (CV) tool and then set the data type to Boolean. But I am not quite sure what to put in the code block or expression field and string variable a precondition to the "Calculate Value" tool?
import arcpy string = arcpy.GetParameterAsText(0) if string == "Ammonia": <code> if string == "pH": <code> if string == "VSS": <code> if string == "COD": <code>
