start/end Tile row/column are not part of the JSON. When you decode AGSTileInfo, execute computeTileBounds method and it will populate all the information in each AGSLOD.Regards,Nimesh
The row/column are not part of the JSON because it has to be calculated at client. Server does not provide that information. Look at this tiled layer JSON. Hence, we have method on AGSTileInfo to calculate. There is not other method to convert AGSTileInfo to JSON. If you want you'll have to write you own method.Hope this helps!Regards,Nimesh
