First post! I am new to GIS, so bear with me.I created a flow direction layer, and the layer has more cells than the input surface layer. How can this be? The reason this is a problem for me is that I am using the direction layer to calculate flow accumulation, and I would like to translate this to drainage area. Thanks in advance
Before you calculate flow direction make sure that the environment is set up not to resample anything:These should be default or same as your surface raster- outputCoordinateSystem - cellSize Also, it's best practice to set the snapRaster to the surface raster.
