o = win32com.client.Dispatch("Excel.Application") o.Visible = 1 o.Workbooks.Add() # for office 97 �?? 95 a bit different! o.Cells(1,1).Value = "Hello"
# Excel module from Mark Hammond # Python Programming on Win 32 import win32com.client import win32com.client.dynamic from pywintypes import UnicodeType, TimeType import pprint import os import time import string class easyExcel: """A utility to make it easier to get at Excel. Remembering to save the data is your problem, as is error handling. Operates on one workbook at a time.""" def __init__(self, filename=None): self.xlApp = win32com.client.dynamic.Dispatch('Excel.Application') if filename: self.filename = filename self.xlBook = self.xlApp.Workbooks.Open(filename) else: self.xlBook = self.xlApp.Workbooks.Add() self.filename = '' def save(self, newfilename=None): if newfilename: self.filename = newfilename self.xlBook.SaveAs(newfilename) else: self.xlBook.Save() def close(self): self.xlBook.Close(SaveChanges=0) del self.xlApp def show(self): self.xlApp.Visible = 1 def hide(self): self.xlApp.Visible = 0 def getBooks(self): return self.xlApp.Worksheets def getName(self,sheet): return self.xlBook.Worksheets(sheet).Name # # now for the helper methods # def getCell(self, sheet, row, col): "Get value of one cell" sht = self.xlBook.Worksheets(sheet) return sht.Cells(row, col).Value def setCell(self, sheet, row, col, value): "set value of one cell" sht = self.xlBook.Worksheets(sheet) sht.Cells(row, col).Value = value def getRange(self, sheet, row1, col1, row2, col2): "return a 2d array (i.e. tuple of tuples)" sht = self.xlBook.Worksheets(sheet) return sht.Range(sht.Cells(row1, col1), sht.Cells(row2, col2)).Value def setRange(self, sheet, leftCol, topRow, data): """insert a 2d array starting at given location. Works out the size needed for itself""" bottomRow = topRow + len(data) - 1 rightCol = leftCol + len(data[0]) - 1 sht = self.xlBook.Worksheets(sheet) sht.Range( sht.Cells(topRow, leftCol), sht.Cells(bottomRow, rightCol) ).Value = data def getContiguousRange(self, sheet, row, col): """Tracks down and across from top left cell until it encounters blank cells; returns the non-blank range. Looks at first row and column; blanks at bottom or right are OK and return None witin the array""" sht = self.xlBook.Worksheets(sheet) # find the bottom row bottom = row while sht.Cells(bottom + 1, col).Value not in [None, '']: bottom = bottom + 1 # right column right = col while sht.Cells(row, right + 1).Value not in [None, '']: right = right + 1 return sht.Range(sht.Cells(row, col), sht.Cells(bottom, right)).Value def getHeaderRange(self, sheet, row, col): """Tracks across from left cell until it encounters blank cells; returns the non-blank range. Looks at first row and column; blanks at bottom or right are OK and return None within the array""" sht = self.xlBook.Worksheets(sheet) # find the bottom row # bottom = row # while sht.Cells(bottom + 1, col).Value not in [None, '']: # bottom = bottom + 1 # right column right = col while sht.Cells(row, right + 1).Value not in [None, '']: right = right + 1 return sht.Range(sht.Cells(row, col), sht.Cells(row, right)).Value def fixStringsAndDates(self, aMatrix): # converts all unicode strings and times newmatrix = [] for row in aMatrix: newrow = [] for cell in row: if type(cell) is UnicodeType: newrow.append(str(cell)) elif type(cell) is TimeType: newrow.append(int(cell)) else: newrow.append(cell) newmatrix.append(tuple(newrow)) return newmatrix def test(): # puts things in a new sheet which it does not save spr = easyExcel() spr.show() input = 'hello' spr.setCell('Sheet1',1,4, input) output = spr.getCell('Sheet1',1,4) print output assert input == output, 'setCell/getCell failed' input = [] for i in range(10): row = [] for j in range(4): row.append(str('(%d,%d)'% (j, i))) input.append(tuple(row)) spr.setRange('Sheet1',2,2,input) output = spr.getRange('Sheet1',2,2,11,5) # get rid of unicode strings output = spr.fixStringsAndDates(output) assert input == output, 'setRange/getRange test failed' #get a contiguous range output2 = spr.getContiguousRange('Sheet1',2,2) dimensions = (len(output2), len(output2[0])) assert dimensions == (10, 4), 'getContiguousRange failed' print 'passed!' # if __name__ == '__main__' : # test()
# load reachs and crosssections from a spreadsheet # getwater3.py # get channel centreline and number nodes uniquely # dropping off duplicates # calculate bearing of nodes in geographic degrees # Kimo # 6 October 2005 # upgrade to average angles for middle points of a reach # 7 October 2005 # 10 October 2005 # offset one more row to allow for max water level calc # does not get all the other water levels, just bottom and max # better to load database of levels for each section for joining later # so that we can create a surface for each time step from same cross sections # ref first field for sorting and joining # pad chainage # removed max row again # but too late, have to have it. # # import win32com.client import win32com.client.dynamic import os,sys from math import * # sys.path.append("d:\\project\\python") import exceldemos homedir = "e:/toolbox/scratch" os.chdir(homedir) xlApp = win32com.client.dynamic.Dispatch('Excel.Application') filename = "e:/example/GISTransfer.xls" spr = exceldemos.easyExcel(filename) f1 = open("channel.txt","w") # polyline generate file f2 = open("channel_att.txt","w") # polyline attributes f3 = open("channel_node.txt","w")# xsection nodes, can load as XY events f4 = open("channel_skip.txt","w")# rejects - duplicate nodes f5 = open("channel_xsec.txt","w")# xsection ref,x,y,theta for joining to xsections # there are multiple worksheets # so loop over all to combine into single output max = 0 lstRef = [] try : for b in spr.getBooks() : max += 1 print "workbook: ",b.Name print "Workbooks found: ",max row = 0 # output file headers print >> f1,'Polyline' # for Toolbox loader print >> f2,'rid,reach' print >> f3,'ref,nodeid,x,y,z,w,theta,rid,reach,chain' print >> f4,'rec,x,y,reach,chain,z,w' # no header for f5 xsec # print >> f5,'ref,x,y,theta,maxwater' rec = 1 id = 0 rn = 0 # skip first sheet for sheetindex in range(2,5) : # get number of columns header = spr.getHeaderRange(sheetindex,3,1) columns = len(header[0]) print "Length of header",columns print "Beginning :",spr.getName(sheetindex) aHeader = spr.getRange(sheetindex,1,1,6,columns) # transpose rows and columns headerpivot = [[r[col] for r in aHeader] for col in range(len(aHeader[0]))] # initialize counters rname = "" rx = 0 ry = 0 i = 0 rej = 0 colcount = len(headerpivot[1:]) print "Columns",colcount for (a,b,c,d,e,w) in headerpivot[1:] : # print rec,a,b,c,d,e,w # a X coordinate # b Y coordinate # ..... snip to fit forum text limit ..... print >> f1,"END" print "records :",rec,"nodes",id,"reaches",rn,"rejects",rej f1.close() f2.close() f3.close() f4.close() f5.close() spr.close() del xlApp except : print "cleanup close" f1.close() f2.close() f3.close() f4.close() f5.close() spr.close() del xlApp
