I'm beginning this process myself for debris removal from a central location for five zonesWhat have you found to work best Cary?
You may try a few more things:
If you have 10.2.2 installed, you can set some registry key in registry editor to generate better clustering result when dynamic seed points are in use:
You can also try Location-Allocation solver to partition the regions, and then use VRP solver to generate routes in each region:
Here is document for Location-Allocation solver: ArcGIS Help (10.2, 10.2.1, and 10.2.2) . To model your problem:
Hope it can solve your problem!
Anna
any update on this? I was hoping to be able to use a set of predetermined garbage route zones (street line feature class) to create routes and indicate how many times the vehicle needs to drive down the road based on the direction field (one-way, 2 way street)
