Dear Sir,
I was using the Gibco basemap with the url: "https://maps.ngdc.noaa.gov/arcgis/rest/services/web_mercator/gebco_2014_hillshade/MapServer" as my basemap in our applciation which is developed using "ArcGIS api for javascript ".But now i am not able to view the basemap. But,when i view the service in arcgis online i am able to view the Gibco basemap.But it is failing using arcgis api for javascript. Can any one help me in this regard
Regards,
Kishore Kumar
Can you post your code?
Dear Ken,
Below I am posting my code.Kindly refer it.
<!DOCTYPE html><html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Simple Map</title> <link rel="stylesheet" href="https://js.arcgis.com/3.25/esri/css/esri.css"> <style> html, body, #map { height: 100%; margin: 0; padding: 0; } </style> <script src="https://js.arcgis.com/3.25/"></script> <script> var map;
require(["esri/map","esri/dijit/Basemap", "esri/dijit/BasemapLayer", "dojo/domReady!"], function(Map,Basemap, BasemapLayer) { var lyrGEBCO = new BasemapLayer( { url : "https://maps.ngdc.noaa.gov/arcgis/rest/services/web_mercator/gebco_2014_hillshade/MapServer" //url : "https://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer" });
var bmapGEBCO = new Basemap ({ layers : [ lyrGEBCO ], title : "GEBCO", thumbnailUrl : "images/mgs_gebco.png" }); map = new Map("map", { basemap: bmapGEBCO, //For full list of pre-defined basemaps, navigate to http://arcg.is/1JVo6Wd center: [-122.45, 37.75], // longitude, latitude zoom: 13 }); }); </script> </head>
<body> <div id="map"></div> </body></html>
You cannot use a dynamic service as a basemap in the map constructor. This code works for tiled services
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta http<SPAN class="operator token">-</SPAN>equiv<SPAN class="operator token">=</SPAN><SPAN class="string token">"Content-Type"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"text/html; charset=utf-8"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1, maximum-scale=1,user-scalable=no"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>Simple Map<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.25%2Fesri%2Fcss%2Fesri.css" target="_blank">https://js.arcgis.com/3.25/esri/css/esri.css</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN> html<SPAN class="punctuation token">,</SPAN> body<SPAN class="punctuation token">,</SPAN> #map <SPAN class="punctuation token">{</SPAN> height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.25%2F" target="_blank">https://js.arcgis.com/3.25/</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="keyword token">var</SPAN> map<SPAN class="punctuation token">;</SPAN> <SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"esri/map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/basemaps"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/domReady!"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>Map<SPAN class="punctuation token">,</SPAN> esriBasemaps<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">//var lyrGEBCO = new BasemapLayer(</SPAN> <SPAN class="comment token"><SPAN>//{ url : "</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fmaps.ngdc.noaa.gov%2Farcgis%2Frest%2Fservices%2Fweb_mercator%2Fgebco_2014_hillshade%2FMapServer" target="_blank">https://maps.ngdc.noaa.gov/arcgis/rest/services/web_mercator/gebco_2014_hillshade/MapServer</A><SPAN>"</SPAN></SPAN> <SPAN class="comment token"><SPAN>//url : "</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fservices.arcgisonline.com%2FArcGIS%2Frest%2Fservices%2FWorld_Topo_Map%2FMapServer" target="_blank">https://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer</A><SPAN>"</SPAN></SPAN> <SPAN class="comment token">//});</SPAN> <SPAN class="comment token">//var bmapGEBCO = new Basemap ({ layers : [ lyrGEBCO ],</SPAN> <SPAN class="comment token">//title : "GEBCO",</SPAN> <SPAN class="comment token">//thumbnailUrl : "images/mgs_gebco.png"</SPAN> <SPAN class="comment token">//});</SPAN> <SPAN class="comment token">// esriBasemaps.gebco = {</SPAN> <SPAN class="comment token"><SPAN>// baseMapLayers: [{ url: "</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fmaps.ngdc.noaa.gov%2Farcgis%2Frest%2Fservices%2Fweb_mercator%2Fgebco_2014_hillshade%2FMapServer" target="_blank">https://maps.ngdc.noaa.gov/arcgis/rest/services/web_mercator/gebco_2014_hillshade/MapServer</A><SPAN>"}</SPAN></SPAN> <SPAN class="comment token">// ],</SPAN> <SPAN class="comment token"><SPAN>// thumbnailUrl: "</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fwww.example.com%2Fimages%2Fthumbnail_2014-11-25_61051.png" target="_blank">https://www.example.com/images/thumbnail_2014-11-25_61051.png</A><SPAN>",</SPAN></SPAN> <SPAN class="comment token">// title: "GEBCO"</SPAN> <SPAN class="comment token">// };</SPAN> <SPAN class="comment token">// map = new Map("map", {</SPAN> <SPAN class="comment token"><SPAN>// basemap: gebco, //For full list of pre-defined basemaps, navigate to </SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Farcg.is%2F1JVo6Wd" target="_blank">http://arcg.is/1JVo6Wd</A></SPAN> <SPAN class="comment token">// center: [-122.45, 37.75], // longitude, latitude</SPAN> <SPAN class="comment token">// zoom: 13</SPAN> <SPAN class="comment token">// });</SPAN> esriBasemaps<SPAN class="punctuation token">.</SPAN>gebco <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN> baseMapLayers<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN> url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fservices.arcgisonline.com%2FArcGIS%2Frest%2Fservices%2FSpecialty%2FDeLorme_World_Base_Map%2FMapServer" target="_blank">https://services.arcgisonline.com/ArcGIS/rest/services/Specialty/DeLorme_World_Base_Map/MapServer</A><SPAN>"</SPAN></SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> thumbnailUrl<SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fwww.example.com%2Fimages%2Fthumbnail_2014-11-25_61051.png" target="_blank">https://www.example.com/images/thumbnail_2014-11-25_61051.png</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN> title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Delorme"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"gebco"</SPAN><SPAN class="punctuation token">,</SPAN> center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">111.879655861</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">40.571338776</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">// long, lat</SPAN> zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">13</SPAN><SPAN class="punctuation token">,</SPAN> sliderStyle<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"small"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Take a look at this post for one way to use a dynamic service in the Basemap Gallery
That service also doesn't appear to be showing anything. It's not getting visualized in the AGOL Map Viewer
