When you say 'merge' did you use the Merge tool or how did you combine the two? Also I am not sure what you mean, 'partially interpolated' because you are using a resampling technique, not necessarily an interpolation. My recommendation would be to combine the two rasters with the CON statement and then choose the finer pixels over the resampled Aster values. This technique will avoid resampling and maintain the original values of the finer resolution data. You must be sure that your pixels line up with the Snap Raster environment setting. That way you can have the best of both rasters. Be advised if the values at the edge are way off, you will still see a 'stair step action' unless you choose to blend/merge. If you are getting artifacts, it may be due to the resampling/merging that is occurring when the pixels do not line up and the values are very different. I am including a blog post on adding two rasters together that discusses this technique.
