var time = new Date(); dojo.place('<div style="padding-bottom:2px;border-bottom:1px solid #B5BCC7;margin-bottom:4px;"><a href="' + result.url + '?time=' + time.getTime() + '" target="_blank">' + title + '</a><br /><span style="font-size:10px;color:#444;">' + time.toLocaleString() + '</span></div>', 'tasks-print-result', 'last');
//functions for printing function openPrint () { clearTextInput('txtTitle'); var fp = dijit.byId('floater_print'); if ((fp.style =="visibility: hidden;") || (fp.style="VISIBILITY:hidden;")) { fp.style.visibility="visible"; fp.show(); } } function setupPrinting(){ //called from my init function var layouts = [{ "layoutName": "FMDC_Landscape", "label": "Landscape - PDF", "format": "PDF", "options": { "legendLayers": [], // empty array means no legend "scalebarUnit": "Miles", "titleText": "", "customTextElements": [{ "legalDescriptionText": "" }, { "subTitleText": "" }] } }, { "layoutName": "FMDC_Portrait", "label": "Portrait - PDF", "format": "PDF", "options": { "legendLayers": [], // empty array means no legend "scalebarUnit": "Miles", "titleText": "", "customTextElements": [{ "legalDescriptionText": "" }, { "subTitleText": "" }] } }]; // create the print templates, could also use dojo.map dojo.forEach(layouts, function(lo){ var t = new esri.tasks.PrintTemplate(); t.layout = lo.layoutName; t.label = lo.label; t.format = lo.format; t.layoutOptions = lo.options; templates.push(t); }); var printer = new esri.dijit.Print({ "map": map, "templates": templates, url: printUrl }, dojo.byId("PrintDiv2")); printer.startup(); dojo.connect(printer, "onPrintStart", function(){ var printTitle = dojo.byId("txtTitle").value; if (printTitle.length < 1) { printTitle = currentCountyName + " County"; } var customElementString; var checkName = ""; if (printName.length > 5) { checkName = 'Owner: ' + printName; } if (printDeed.length < 16) { //feature has deed book and page information customElementString = [ {"legalDescriptionText": checkName+' Description :' + fullLegalString}, { "subTitleText": print_subTitle} ]; }else{ customElementString = [ {"legalDescriptionText": checkName+' Description :' + fullLegalString + '' + printDeed}, { "subTitleText": print_subTitle} ]; } // console.log("fullLegalString = "+fullLegalString + "<br> subTitleText = " + print_subTitle); for (var i = 0; i < templates.length; i++) { this.templates.layoutOptions.titleText = printTitle; this.templates.layoutOptions.customTextElements = customElementString; } dojo.connect(printer, "onError", function(err){ console.log("Printer Error: " + err); }); dojo.connect(printer, 'onPrintComplete', function(value){ console.log('The url to the print image is : ' + value.url); }); }); }
<div id="floater_print" dojoType="dojox.layout.FloatingPane" title='Create Print Page' dockTo="dock_print" style="visibility:hidden; height:260px" closable="false" resizable="true" dockable="true"> <div id="info"> <div id="note"> <ol> <li> Enter a Title <input id="txtTitle" style="width:250px" type="text" value="Enter a map title" class="textBox" onclick="clearTextInput('txtTitle');" /> </li> <li> Click the dropdown arrow on the Print button to choose Landscape or Portrait. </li> <li> The 'Printing' prompt indicates your page is being generated. </li> <li> When the printout is ready, the print button will change to a link Printout.</li> <li>Click Printout to view your PDF.</li> </ol> </div> <div id="PrintDiv2" > </div> </div> </div>
dojo.connect(printer, 'onPrintComplete', function(value){ var time = new Date(); var url = value.url + '?time=' + time; console.log('The url to the print image is : ' + url); });
Custom Print Services generates the same 32-character string for all its output files, which causes old print requests to be displayed again.Steps to reproduce:1. Submit several print requests to the OOTB 10.1 print service and notice that each output filename includes a random 32-character sequence.2. Publish a Custom Print Service (using existing templates) and notice that the same 32-character string is repeated in all output files. Only incremented numbers appended to the end guarantee the filename is unique (see attached screenshots).This causes a problem in web applications when an additional print request is submitted after previous jobs have already been deleted from the server. Because the response URL can easily be identical, stale content from the cache might be displayed instead of the correct printout.Sample application attached (can also be found at http://[internalserver]/printTask.html).1. Open the application and click print2. Pan the map to a different location3. Wait 15 minutes and send another print requestNotice that if the URL is identical, the first printout will be displayed again. It is necessary to force a refresh of the page to display the appropriate output.
i just wanted to chime in and let you all know that this is a REST bug that I logged a little while back which has been tested and confirmed fixed in 10.2.[NIM090204:When using a custom print service, sometimes old print requests are returned due to the way output files are named]sorry for the inconvenience.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Print Task Example</title> <link rel="stylesheet" type="text/css" href="https://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" type="text/css" href="https://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/esri/dijit/css/Popup.css"> <link rel="stylesheet" type="text/css" href="https://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/dojo/dojox/layout/resources/FloatingPane.css"> <link rel="stylesheet" type="text/css" href="https://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/dojo/dojox/layout/resources/ResizeHandle.css"> <link rel="stylesheet" type="text/css" href="https://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/esri/css/esri.css" > <link type="text/css" rel="stylesheet" href="css/style.css"> <script type="text/javascript">var dojoConfig = {parseOnLoad: true};</script> <script type="text/javascript" src="https://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.4"></script> <script type="text/javascript"> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("dojox.layout.FloatingPane"); dojo.require("dijit.form.Button"); dojo.require("dijit.form.Select"); dojo.require("esri.map"); dojo.require("esri.dijit.Popup"); dojo.require("esri.layers.FeatureLayer"); dojo.require("dijit.form.Button"); dojo.require("esri.tasks.PrintTask"); var loading; var map; var spatialReference; var idFromClick = true; var districtLayer; var geometryPt; var currentExtent; var layouts = []; var templates = []; var template; var printServiceUrl = "https://myPrintServerName/arcgis/rest/services/printTemplate/ExportWebMap/GPServer/Export Web Map"; function init() { spatialReference = new esri.SpatialReference({wkid: 102100 }); startExtent = new esri.geometry.Extent(-10583000, 4287025, -9979000, 4980462, spatialReference); map = new esri.Map("map",{ extent:startExtent }); var basemap = new esri.layers.ArcGISTiledMapServiceLayer("https://server.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Light_Gray_Base/MapServer"); map.addLayer(basemap); roadLayer = new esri.layers.ArcGISDynamicMapServiceLayer("https://services.arcgisonline.com/ArcGIS/rest/services/Reference/World_Transportation/MapServer",{id:'countyLayer'}); map.addLayer(roadLayer); dojo.connect(dijit.byId('map'), 'resize', map, map.resize);//resize the map when the browser resizes setUpPrinting(); }//end init function function clearTextInput (id) { dojo.byId(id).value=""; } //functions for printing function openPrint () { clearTextInput('txtTitle'); var fp = dijit.byId('floater_print'); if ((fp.style = "visibility: hidden;") || (fp.style = "VISIBILITY:hidden;")) { fp.style.visibility="visible"; fp.show(); } } function setUpPrinting() { var templateList = dijit.byId("templateSelect"); layouts = [{ "layoutName": "Custom_Landscape", "label": "Landscape", "format": "PDF", "options": { "legendLayers": [], // empty array means no legend "scalebarUnit": "Miles", "titleText": "" } }, { "layoutName": "Custom_Portrait", "label": "Portrait", "format": "PDF", "options": { "legendLayers": [], // empty array means no legend "scalebarUnit": "Miles", "titleText": "" } }]; dojo.forEach(layouts, function(layout){ var pTemplate = new esri.tasks.PrintTemplate(); pTemplate.layout = layout.layoutName; pTemplate.label = layout.label; pTemplate.format = layout.format; pTemplate.layoutOptions = layout.options; pTemplate.showAttribution = false; templates.push(pTemplate); templateList.addOption({ label: layout.label, value: layout.label }); }); } function submitPrint() { var deferred; var printTitle = dojo.byId("txtTitle").value; var printParams = new esri.tasks.PrintParameters(); printParams.map = map; var status = dojo.byId("printStatus"); status.innerHTML = "Printing ..."; var e = dijit.byId("templateSelect"); var choice = e.value; if (choice == "Portrait") { template = templates[1]; }else{ template = templates[0]; } if (!template) { template = templates[0]; } printParams.template = template; template.layoutOptions.titleText = printTitle; var printTask = new esri.tasks.PrintTask(printServiceUrl,printParams); //printTask.execute(printParams,printComplete,printError); deferred = printTask.execute(printParams); deferred.addCallback(function (response){ // console.log("response = " + response.url); status.innerHTML = ""; var select = dijit.byId("templateSelect"); var selectOptions = select.getOptions(); select.set("value", "Choose Print Format"); var link = dojo.byId("printLink"); link.innerHTML = "<a href="+response.url+ " target=_blank ;'>Printout</a> "; link.onclick = function(){link.innerHTML = '';}; }); deferred.addErrback(function (error) { console.log("Print Task Error = " + error); status.innerHTML = "Print Error" + error; }); } function printError(err) { console.log("Printer Error: " + err); } dojo.addOnLoad(init); </script> </head> <body class="claro"> <div dojotype="dijit.layout.BorderContainer" data-dojo-props="design:'headline'" style="width: 100%; height: 100%; margin: 0; border:0px;"> <div id="header" dojotype="dijit.layout.ContentPane" region="top"> Print Task Example </div> <div dojotype="dijit.layout.ContentPane" id="centerPane" region="center"> <button id="btnPrint" dojotype="dijit.form.Button" onClick="openPrint();">Print</button> <div id="map" dojotype="dijit.layout.ContentPane" title="Map" > <div dojoType="dojox.layout.Dock" id="dock_print"></div> </div> <div id="floater_print" dojoType="dojox.layout.FloatingPane" title="Print Tools" dockTo="dock_print" style="visibility:hidden" closable="false" resizable="true" dockable="true" > <div id="note"> <ol> <li> Enter a Title <input id="txtTitle" style="width:250px" type="text" value="Enter a map title" class="textBox" onclick="clearTextInput('txtTitle');" /> </li> <li> Click the dropdown arrow on the Print format to choose Landscape or Portrait. </li> <li> The 'Printing' prompt indicates your page is being generated. </li> <li> When the printout is ready, click Printout to view your PDF.</li> </ol> <select id="templateSelect" data-dojo-type="dijit.form.Select" > <option>Choose Print Format</option> </select> <button id="btnPrintSubmit" dojotype="dijit.form.Button" onClick="submitPrint();">Print</button> </div> <div id="printStatus"></div> <div id="printLink"></div> </div> </div> </body> </html>
dojo.connect(printer, "onPrintComplete", function(result){ var currentTime = new Date(); result.url += "?ts="+currentTime.getTime(); });
deferred = printTask.execute(printParams); deferred.addCallback(function (response){ var time = new Date(); var outputUrl = response.url + '?time=' + time; var link = dojo.byId("printLink"); link.innerHTML = "<a href="+outputUrl+ " target=_blank ;'>Printout</a> "; // link.innerHTML = "<a href="+response.url+ " target=_blank ;'>Printout</a> "; });
function submitPrint() { var deferred; var printTitle = dojo.byId("txtTitle").value; var printParams = new esri.tasks.PrintParameters(); printParams.map = map; var status = dojo.byId("printStatus"); status.innerHTML = "Printing ..."; var e = dijit.byId("templateSelect"); var choice = e.value; if (choice == "Portrait") { template = templates[1]; }else{ template = templates[0]; } if (!template) { template = templates[0]; } printParams.template = template; template.layoutOptions.titleText = printTitle; var printTask = new esri.tasks.PrintTask(printServiceUrl,printParams); deferred = printTask.execute(printParams); deferred.addCallback(function (response){ var d = new Date(); var dateTime = d.getTime(); var outputUrl = response.url + '?time=' + dateTime; status.innerHTML = ""; var select = dijit.byId("templateSelect"); var selectOptions = select.getOptions(); select.set("value", "Choose Print Format"); var link = dojo.byId("printLink"); link.innerHTML = "<a href="+outputUrl+ " target=_blank ;'>Printout</a> "; // link.innerHTML = "<a href="+response.url+ " target=_blank ;'>Printout</a> "; link.onclick = function(){link.innerHTML = '';}; }); deferred.addErrback(function (error) { console.log("Print Task Error = " + error); status.innerHTML = "Print Error" + error; }); }
