I have written a code to check if areas will be inundates when a certain value is added, the code doesn't give any errors but at the same time it does do anything.
Just says running code complete, I am not even sure what the problem is. My code is here
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="keyword token">import</SPAN> os<SPAN class="punctuation token">,</SPAN> sys<SPAN class="punctuation token">,</SPAN> traceback<SPAN class="punctuation token">,</SPAN> shutil
<SPAN class="keyword token">import</SPAN> numpy <SPAN class="keyword token">as</SPAN> np
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>overwriteOutput <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">True</SPAN>
<SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN>
outputfolder <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN>
fc <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN>
inputraster <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#check to see if the arcinfo license is on</SPAN>
<SPAN class="keyword token">if</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>CheckExtension<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Spatial"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">==</SPAN> <SPAN class="string token">"Available"</SPAN><SPAN class="punctuation token">:</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CheckOutExtension<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Spatial"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddError<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Spatial analyst extension is not licensed."</SPAN><SPAN class="punctuation token">)</SPAN>
sys<SPAN class="punctuation token">.</SPAN>exit<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#set the Progressor</SPAN>
<SPAN class="comment token">#arcpy.SetProgessor("step","Checking input requirements....",0,9,1) </SPAN>
<SPAN class="comment token">#Process :create an out put folder</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CreateFileGDB_management<SPAN class="punctuation token">(</SPAN>outputfolder<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"output.gdb"</SPAN><SPAN class="punctuation token">)</SPAN>
outputgdb <SPAN class="operator token">=</SPAN> outputfolder <SPAN class="operator token">+</SPAN> <SPAN class="string token">"\\output.gdb"</SPAN><SPAN class="operator token">+</SPAN> os<SPAN class="punctuation token">.</SPAN>step
<SPAN class="comment token">#create path to store raster data</SPAN>
clippedraster <SPAN class="operator token">=</SPAN> outputfolder <SPAN class="operator token">+</SPAN> <SPAN class="string token">"clippedraster"</SPAN>
flooded <SPAN class="operator token">=</SPAN> outputfolder <SPAN class="operator token">+</SPAN><SPAN class="string token">"floodedarea"</SPAN>
<SPAN class="comment token">#check to see if the inputs are in the same projection</SPAN>
desccs_ras <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Describe<SPAN class="punctuation token">(</SPAN>inputraster<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>SpatialReference
desccs_fc <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Describe<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>SpatialReference
<SPAN class="keyword token">if</SPAN> desccs_ras<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">==</SPAN> <SPAN class="string token">"Unknown"</SPAN> <SPAN class="operator token">and</SPAN> desccs_fc<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">==</SPAN> <SPAN class="string token">"Unknown"</SPAN><SPAN class="punctuation token">:</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Your data does not have a defined spatial reference"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> desccs_ras<SPAN class="punctuation token">.</SPAN>projectionName <SPAN class="operator token">==</SPAN> desccs_fc<SPAN class="punctuation token">.</SPAN>projectionName<SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">""</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddError<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"The input Data should be in the same projection"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">del</SPAN> desccs_fc<SPAN class="punctuation token">,</SPAN>desccs_ras
<SPAN class="comment token">#remove the areas below sea level</SPAN>
currentRaster <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Raster<SPAN class="punctuation token">(</SPAN>inputraster<SPAN class="punctuation token">)</SPAN>
rastertoclip <SPAN class="operator token">=</SPAN> Con<SPAN class="punctuation token">(</SPAN>currentRaster<SPAN class="operator token">>=</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>currentRaster<SPAN class="punctuation token">,</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#clip the raster data to the interested zone extend</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>Clip_management<SPAN class="punctuation token">(</SPAN>rastertoclip<SPAN class="punctuation token">,</SPAN>"<SPAN class="comment token">#",clippedraster,fc,"#","ClippingGeometry","MAINTAIN_EXTENT")</SPAN>
clip_raster <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Raster<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"in_memory"</SPAN><SPAN class="punctuation token">)</SPAN>
areasbelow <SPAN class="operator token">=</SPAN> clip_raster <SPAN class="operator token"><=</SPAN> <SPAN class="number token">2</SPAN>
areasbelow<SPAN class="punctuation token">.</SPAN>save<SPAN class="punctuation token">(</SPAN>flooded<SPAN class="punctuation token">)</SPAN>
md <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>MapDocument<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"CURRENT"</SPAN><SPAN class="punctuation token">)</SPAN>
df <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>ListDataFrames<SPAN class="punctuation token">(</SPAN>md<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
result <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>MakeRasterLayer_management<SPAN class="punctuation token">(</SPAN>flooded<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"FloodedArea"</SPAN><SPAN class="punctuation token">)</SPAN>
layer <SPAN class="operator token">=</SPAN> result<SPAN class="punctuation token">.</SPAN>getOutput<SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>AddLayer<SPAN class="punctuation token">(</SPAN>df<SPAN class="punctuation token">,</SPAN> layer<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"AUTO_ARRANGE"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">except</SPAN><SPAN class="punctuation token">:</SPAN>
tb <SPAN class="operator token">=</SPAN> sys<SPAN class="punctuation token">.</SPAN>exc_info<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN>
tbinfo <SPAN class="operator token">=</SPAN> traceback<SPAN class="punctuation token">.</SPAN>format_tb<SPAN class="punctuation token">(</SPAN>tb<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
pymsg <SPAN class="operator token">=</SPAN> <SPAN class="string token">"PYTHON ERRORS:\nTraceback Info:\n"</SPAN> <SPAN class="operator token">+</SPAN> tbinfo <SPAN class="operator token">+</SPAN> <SPAN class="string token">"\nError Info:\n "</SPAN> <SPAN class="operator token">+</SPAN> \
str<SPAN class="punctuation token">(</SPAN>sys<SPAN class="punctuation token">.</SPAN>exc_type<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN> <SPAN class="string token">": "</SPAN> <SPAN class="operator token">+</SPAN> str<SPAN class="punctuation token">(</SPAN>sys<SPAN class="punctuation token">.</SPAN>exc_value<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">"\n"</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
